Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 01-17-2005, 04:37 PM   #1
jjameson
Member#: 4986
2002 BlzYel JDMSTiv7
GRP 08 FXT
Default Complete Moretted wiring Diagram needed
I have a older set of Morettes non HID with out the plug and play that I have had on for like 3 years. No problem with the basic wiring to the stock headlights. I need more info. The last time I went for the brights they seemed not to be working. When I looked at the problem I could see one of the relays had a corrision at the connections. The relay was in bad shape. The relay had pulled out of the top case that mounts to the back of the headlights. The relay needs replacing. I took the headligths off and put my fugly ones on so I could clean up the mess on the Morettes on the bench top. In taking the morettes off the wires into the back of the realy were corroded and broke off. I went and got a new relay but I need a diagram for what wires go to what connections on the relay. Does anyone have a wiring diagram that includes relay wiring positions as well? When I rewire and clean up the mess I was going to build my own plug and play connections. Any suggestions, dismantle a 9007 and use the base.
jjameson is offline   Reply With Quote
Old 01-17-2005, 08:18 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Did you check the fuse that connects to the battery? That is the fuse for the Morette high beams.
Old 01-17-2005, 09:18 PM   #3
jjameson
Member#: 4986
GRP 08 FXT
Nope not the fuse, it's definetly the wiring to the relay(s). On the passager side, the corrosion on that one relay that was hanging and not secured to the back of the headlight is pretty bad. The wires broke off at the back they were so brittle. Also the powered fused wire from the battery to the one relay that is on the back of the high beam on the drives side is also pulled out/broken off.
I need relay wiring diagram or info.....
Old 01-17-2005, 09:39 PM   #4
brunetmj
Member#: 8023
2004 2.5 RS
If you PM me with an email address I have some information. I did a sketch of the morette relay system.
However I did it at a time in which I did not know a lot about 12 volt wiring and did not know how to label the relay pins. However it is sketched accurately and may be of some help.
brunetmj is offline   Reply With Quote
Old 01-17-2005, 09:44 PM   #5
brunetmj
Member#: 8023
2004 2.5 RS
This is what it looks like. However my photo hosting web site cuts out parts of my uploads sometimes.
Old 01-19-2005, 08:01 PM   #6
jjameson
Member#: 4986
GRP 08 FXT
Thanks alot, that is a good start. The relay pins are labled with numbers 85, 87, 87a, 86, and 30 (For the 5 pin relays). One for each pin. On the Hella relays this info is molded into the top of the relay, hard to see unless clean and well lit. 87a is the middle pin thats the easy one. 87 and 87a are the switched pair so I am guessing the high beam is associated with those two.
Is there any way you could get a look at your Morettes and grab the realy pin ID #'s that would be fantastic.
Is there one of the vendors on the board that can take a look at a new set out of stock??
Old 01-19-2005, 09:43 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
On any relay, 85 and 86 are the coil wires. 30 is the common contact, 87 is normally open and 87a is normally closed.
Old 01-20-2005, 12:58 AM   #8
brunetmj
Member#: 8023
2004 2.5 RS
I no longer have the morettes. When I did that diagram I could not see the pin numbers because of their position on the morettes.
Below is another sketch but ignore the pin numbers as I was just guessing. Also as I mentioned my hosting service cuts out parts of these diagrams I am displaying. You need to give me an email address if you want to see the whole thing. If anyone wants to help label these things it would be helpful.
Old 05-20-2005, 04:43 PM   #9
Amazake
Member#: 9889
bump I sent a PM to you brunetmj
Thanks
Amazake is offline   Reply With Quote
Help! V.4 wiring diagram needed! LVSUBARU Subaru Conversions 9 05-23-2005 02:51 PM
Wiring diagram needed....for a volvo chris84bond Off-Topic 4 04-21-2005 12:50 AM
04 STi guages wiring diagram needed... SilverBoosted Electrical & Lighting 10 06-22-2003 11:52 AM
EJ18 and EJ25 wiring diagrams needed Geek Guy Engine Management & Tuning 0 11-19-2002 10:39 PM
BG stock headlight wiring diagram needed monovich Legacy Forum 6 09-09-2002 06:16 PM
