Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 01-17-2005, 05:46 PM   #1
root
Member#: 55854
2004 STi
Blue/silver
Default Hydra = no cruise control right? Anything else?
I couldn't really find anything on the Element site regarding missing features when swapping out the stock ECU. I believe I read the cruise controls is out, yes? Anything else? DCCD? Air bags? What all does the stock ECU control other than fuel/timing/boost/other-engine stuff?
root is offline   Reply With Quote
Old 01-17-2005, 06:20 PM   #2
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
From what I understand that is the only thing missing. And it sounds like Phil isn't going to attempt to get it working again. Apparently he is very concerned with the resulting safety issues that a cruise control system on a drive by wire car has.
offset
offset is offline   Reply With Quote
Old 01-17-2005, 06:31 PM   #3
root
Member#: 55854
2004 STi
Blue/silver
Cool. Do you know if the DCCD and airbags are controlled by the ECU? I'm just wondering how accurately the replication of those features would be. Might even be interesting to tweak the DCCD or add a yaw sensor to the 2004 (not that I imagine it is possible with current Hydra, does it have additonal external sensor inputs?).
Old 01-17-2005, 06:38 PM   #4
RadarOnPaws
Member#: 47658
Wouldn't you think that Subaru would have a more conservative attitude regarding safety than an aftermarket parts company?
RadarOnPaws is offline   Reply With Quote
Old 01-17-2005, 07:13 PM   #5
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
I would to, but I guess that isn't the case this time.
offset
Old 01-17-2005, 07:16 PM   #6
wgknestrick
Member#: 32576
04 STI
Cruise is only thing that is absent.
<------Don't ask me how I know
wgknestrick is offline   Reply With Quote
Old 01-17-2005, 07:55 PM   #7
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Subaru is concerned with your safety but they use a separate computer for the cruise control where we would have to use the engine management computer. This would result in ignoring the pedal position while in cruise which is a safety issue since the throttle plate position would differ from the two accelerator position sensors. Normally when this happens a fail safe circuit is tripped in the Hydra as it would most likely mean a "stuck" throttle.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 01-17-2005, 07:59 PM   #8
root
Member#: 55854
2004 STi
Blue/silver
Thanks Phil. Any comment on how the airbags and DCCD work?
Old 01-17-2005, 09:22 PM   #9
RadarOnPaws
Member#: 47658
Ah. Thanks.
Old 01-17-2005, 09:35 PM   #10
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Non-DBW Hydras retain all factory features correct?
BAN SUVS is offline   Reply With Quote
Old 01-17-2005, 09:49 PM   #11
Element Tuning
Member#: 54918
673 WHP Element
That is correct but remeber since there is no OEM computer there is no OBD2. All other features of the STI remain as they did from the factory, just no OBD2 and no cruise control.
Thanks,
Phil
Old 01-17-2005, 09:51 PM   #12
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Oh, so the CC computer is disabled with the Hydra, or is it just missing some inputs?
Old 01-18-2005, 01:33 AM   #13
Element Tuning
Member#: 54918
673 WHP Element
Only on the DBW cars, standard throttle cars retain cruise control.
Phil
Old 01-18-2005, 01:51 AM   #14
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Thanks Phil.
Old 01-18-2005, 02:57 AM   #15
bboy
Member#: 56468
04 Improved STI
Dirty White
DCCD is controlled by it's own logic unit. The airbags are controlled by little accelerometers that are part of the bag units, and replaced with the bag should it go off. Cruise is a nice feature that I've never had (can you believe that). I'll give it up anyday for the Hydra's flexability. OBDII would be nice for those States that use it, but I somehow doubt I could pass an emissions check by that mode of assessment.
Old 01-18-2005, 10:36 AM   #16
root
Member#: 55854
2004 STi
Blue/silver
Cool. Thanks for the info.
Old 11-25-2010, 04:06 AM   #17
slowgenius
Member#: 48350
0304 0712 WRX/Sti
Default cruise
Has there been any change with the cruise not working with the drive by wire cars?
slowgenius is offline   Reply With Quote
Old 03-26-2012, 01:15 AM   #18
anOBP04sti
Member#: 314614
Bump for an answer!
anOBP04sti is offline   Reply With Quote
Old 03-27-2012, 09:49 PM   #19
slowgenius
Member#: 48350
0304 0712 WRX/Sti
Phil says no cruise unless you are using cable throttle.
Old 03-30-2012, 02:51 PM   #20
Element Tuning
Member#: 54918
673 WHP Element
Yes cruise control is coming. I guess never say never. LOL!
This will only be a 2.7 option and it's only an Epsilon option so it won't be cheap. Hydra EMS wants me to test this extensively before they release it to the public which means no beta testers.
Old 06-09-2012, 12:47 AM   #21
anOBP04sti
Member#: 314614
Phil,
I'm under the assumption after reading this thread that my Hydra will soon be able to have cruise control?
Let me know what the status is on that as I am extremely happy to hear this. This was the main downfall for me with the Hydra and why I almost sold mine.
Thanks
Old 06-11-2012, 11:17 PM   #22
Element Tuning
Member#: 54918
673 WHP Element
Its still in development but its only going to be an option on 2.7 or newer and at this point there are no public details available. Its going to require additional hardware above even above the current 2.7.
Old 06-12-2012, 12:00 AM   #23
anOBP04sti
Member#: 314614
Phil,
I don't know if you remembered me, but I got the car from the kid in Maryland that owed you money. I believe this car has the Hydra 2.7 Nemisis EMS. Please correct me if I am wrong if you can
Thanks
Old 06-12-2012, 12:24 PM   #24
Element Tuning
Member#: 54918
673 WHP Element
Originally Posted by anOBP04sti View Post
Phil,
Thanks
Yes and he's all paid up so no problems there. Yes it's a 2.7 but I can't tell you when we'll release the cruise control option or what it will cost at this point.
Old 10-14-2012, 03:25 PM   #25
Joelo_00
Member#: 175095
Chapter/Region: PRSIC
2000 RS
Where can we find the options currently included on the different 2.7 versions? (Alpha, Beta, Gamma, Delta, Epsilon)
Joelo_00 is offline   Reply With Quote
My Hydra has cruise control!!!!! keaniegenie Engine Management & Tuning 9 06-21-2006 01:01 PM
Cruise actuator but no cruise control!! Improviser Normally Aspirated Powertrain 14 11-13-2002 05:48 PM
Why No Cruise Control Ind. Light in WRX? rally_wannabe Newbies & FAQs 7 05-16-2002 04:56 PM
No cruise control... JGard Normally Aspirated Powertrain 10 05-25-2001 09:28 AM
