Welcome to the North American Subaru Impreza Owners Club Friday December 26, 2014
Old 01-17-2005, 05:55 PM   #1
Discjoshie
Member#: 43717
2000 2.5 RS
Default Aftermarket ECU and Inspections
I live in Maryland, and I know that if your car has and OBD-II (stock) then they will use the OBD-II diagnostic plug for emissions inspection. If I had aftermarket management for a supercharged RS, in the form of a parallel sort of setup like a TEC-II or TEC3, or had a full standalone of somekind, like a Link+, would I be able to pass inspection? How would they test? If I tell them my ECU is and aftermarket part, will they probably do a tail pipe test instead or otherwise??
Anyone with aftermarket ECUs, especially from Maryland, have any input?
Thank,
Josh
Discjoshie is offline   Reply With Quote
Old 01-17-2005, 05:59 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
If your car is supposed to have OBD-II and they plug in the port to scan and get nothing, you will fail.
Calvin
cnk is offline   Reply With Quote
Old 01-17-2005, 06:54 PM   #3
dentprone
Member#: 18588
1999 busted car
silverthorn
find out how your obd2 system works and make a module and hook it up to your obd2 port, that tells the state inspector scan tool that there is no DTC's and the system is ready sell it at walmart and you can be a millionare
dentprone is offline   Reply With Quote
Old 01-21-2005, 07:34 PM   #4
Discjoshie
Member#: 43717
2000 2.5 RS
Bump for an actual answer. Anyone have any solutions? I just need the car to run well, not lean or rich with bigger injectors and fuel pump with about 6.5 lbs of boost. I guess I need to maintain my stock ECU so no standalones. Help?
Old 01-21-2005, 08:17 PM   #5
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
A piggyback like the UTEC or XEDE will pass through OBDII stuff, and so will pass a nonvisual inspection.
I doubt a standalone will pass.
I am not sure about a reflash, but I would imagine that it would pass.
mcowger is offline   Reply With Quote
Old 01-21-2005, 11:05 PM   #6
awilson529
Member#: 38867
11 Mazda
Interested in a solid answer... I'm planing on ditching the aP and going Hydra. This has been in the front of my mind since I thought of switching EMs.
Adam
awilson529 is offline   Reply With Quote
Old 01-21-2005, 11:58 PM   #7
OppositeLock
Member#: 54060
Now: v8 207/v6 5mt
Then: JRTune fastest td04
Interested as well. If anybody has any NJ inspection/EM info.
Dave
OppositeLock is offline   Reply With Quote
Old 01-22-2005, 01:34 AM   #8
Discjoshie
Member#: 43717
2000 2.5 RS
Can someone tell me more about the UTEC or link me to a thread about what it is and does exactly? Is it simple to use and tune? Costs and where to buy? Thanks.
Old 01-22-2005, 10:58 PM   #9
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
i beleive www.worldoneperformance.com has a section on their site about it.
David Medina is offline   Reply With Quote
Old 01-22-2005, 11:10 PM   #10
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
UTEC is a piggy back computer that intercepts signals from your ECU and modifies what the ECU sees and putputs. It attaches to your exisitng computer. Cost is about $950. As for tuning - its about as simple to tune as you can get, but that doesn't mean you can just pick up car tuning. You have to know what you are doing to use it, or you WILL blow up your engine. So, yes, it very simple to use and tune, but its not like there is a 'make 35HP' button .
Many vendors sell it. i got mine from Gruppe-S in a deal that includes 1 hr of dyno tuning (well worth it to get it tuned).
before spending a grand on this stuff, I throughly researched every available engine computer. My requirements were that I wanted something that would be undetectable by a nonvisual inspection (that rules outa standalone ECU) and something that was removeable (ruling out an ECU reflash) and something that could not be detected by a dealer (ruling out a Cobb AP) and easy to use without custom software (ruling out the Vishnu XEDE).
Old 01-23-2005, 12:31 AM   #11
Discjoshie
Member#: 43717
2000 2.5 RS
Well I just learned that the UTEC is exclusively for WRXs. Oops. I have been trading emails with Bill from I-Speed and he said that there will be some kind boosted RS reflash pretty soon. I don't mean to cause a stir, but I sure hope that it comes out soon and it is effective and of high quality, as per I-Speed's reputation. If anyone has any other suggestions or information I would love to hear it. Thanks for your help, guys.
Old 01-23-2005, 05:02 AM   #12
awilson529
Member#: 38867
11 Mazda
I thought there was a UTEC available for Evo's also? Or is it still in development?
Old 01-23-2005, 06:01 AM   #13
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
There is an EVO UTEC, as well as an STi UTEC> However, there is no RS UTEC.
Old 01-29-2005, 01:48 AM   #14
erice1984
Member#: 11778
1980 VWRabbit Diesel
w/AAZ Swap
i thought of a way. not sure it will work, but if you left the tuning to your standalone and jus gave your stock ecu all the sensors but no control, then have the stock ecu report to the obd2 plug thing so when they read it everything is a-ok
erice1984 is offline   Reply With Quote
FS : OH: 04' STI ECU and 04' STI DCCD Controller pannell77 Engine/Power/Exhaust 18 07-28-2010 08:14 AM
Problem w/ ECU? State Inspection? MykeM Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-22-2007 04:25 PM
WTB:STOCK 02-03 WRX ECU or any aftermarket ECU for WRX 02-03 SpoonTypeR Vancouver Impreza Club Forum -- VIC 17 11-25-2005 11:48 AM
Reflashed ECU and passing inspection? SjpWrx Tri-State Area Forum 2 10-05-2005 08:12 PM
Splitting the stock EGT sensor signal to both ECU and a aftermarket gauge Worxman02 Electrical & Lighting 9 01-15-2005 12:26 PM
