Welcome to the North American Subaru Impreza Owners Club Saturday April 19, 2014
Old 01-17-2005, 08:52 PM   #1
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
Default Security Dash Light Flash Hack... help?
FOR 02+ WITHOUT security system!
when i opened up my gauge cluster in order to change the color, i noticed i have an LED behind the security light... is there any way to hack it to make it flash??? could i splice a timed circuit in the wiring harness in order to make it flash, even though i don't have the security system installed?
I feel like the LED scanners you can buy to make it look like you have a security system are too tacky and ugly, but if i could make the stock LED flash i'd be happy, at least until i get a security system installed. i'll look over my ECU pinout, but any at least theoretical help would be greatly appreciated.
okay the ECU doesn't control it... how can i do this?
Handsdown is offline   Reply With Quote
Old 01-17-2005, 10:04 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Yes, if you get the wiring diagram you'll see that the security LED has a constant 12V connection and switched negative. When you have the security module the negative is controlled by the module which flashes the LED depending on the system status. Without the module, you can operate the LED by providing your own circuitry to switch the negative. The connection is available via the factory harness connection where the security module would plug in.
Old 01-17-2005, 10:12 PM   #3
brunetmj
Member#: 8023
2004 2.5 RS
I agree. However i never saw the point of a flashing security LED that no one can see unless their looking in your window. Personally i just wired a small LED that is just peeking through the head liner above the rear view mirror. But to each his own.
brunetmj is offline   Reply With Quote
Old 01-17-2005, 10:15 PM   #4
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
hmm... so if i rigged up a radio-shack "flash" circuit, it would flash even during driving, correct? that wouldn't be so cool...
Old 01-17-2005, 11:36 PM   #5
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
which is why you wire in a relay to have it turn off when the ignition is on.
tooocool49723 is offline   Reply With Quote
Dash lights flash/flicker when headlights are turned on 99ScoobyAWD Electrical & Lighting 4 08-12-2012 11:21 PM
Dash Lights flashing after clutch swap? Swiffer Car Audio, Video & Security 1 11-11-2007 05:58 PM
Installed new HU and dash lights dont work, help! wrxboy944 Car Audio, Video & Security 10 11-30-2005 07:29 PM
dash light flashing, and probably not good pilfflip Legacy Forum 2 02-20-2004 09:43 AM
Dash lights and cornermarkers HELP!!!!!!! PeterPan Technical Forum Archive 11 07-11-2000 02:27 PM
