Old 01-17-2005, 11:48 PM   #1
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Default Aftermarket Knock sensor locations on STI
Where are you putting Tuner pro, Knock Link bosch sensors on the STI.
I have my sensors placed.
UTEC-obviously uses stock sensor
Knock link-DS front intake runner grounding bolt
Tuner pro-DS rear intake runner ontop of intercooler bracket or Passenger side grounding bolt.
Any other good points as I have another sensor coming
Wombat North is offline   Reply With Quote
Old 01-18-2005, 08:08 AM   #2
happasaiyan
Member#: 37731
i put my tuna sensor on the recommended bolt under where the stock IC would be.
happasaiyan is online now   Reply With Quote
Old 01-18-2005, 02:53 PM   #3
Wombat North
Member#: 21267
STI, EWG 8cm Green
Who's recommendation?
Old 01-18-2005, 03:12 PM   #4
happasaiyan
Member#: 37731
Old 01-18-2005, 07:32 PM   #5
wgknestrick
Member#: 32576
04 STI
This is the best place I could find as well. Hopefully you have a FMIC and can get to this easily
wgknestrick is offline   Reply With Quote
Old 02-01-2005, 08:17 PM   #6
Wombat North
Member#: 21267
STI, EWG 8cm Green
Forgot about this post
Have any of you actually looked where the stock sensor is on the STI. Buried.
The bolt you use for the aftermarket sensor on the WRX is taken up by a bracket on the STI. Are you just bolting the sensor over the top of the bracket?
I'll take some pics tonite
Old 02-02-2005, 07:57 AM   #7
happasaiyan
Member#: 37731
i think its on top of the bracket? i vaguely remember there being a bracket. i mightve taken it off? i dont remember what it was attached to. haha.
Old 02-02-2005, 01:16 PM   #8
Wombat North
Member#: 21267
STI, EWG 8cm Green
Some days I'm guilty of brain farts.
The bracket is holding the coolant line for the throttle body and all that was required was to put the sensor under the bracket. Boy that was hard
FWIW
No difference in knock 'hearing" between the above position and the grounding bolt on the DS intake manifold according to knock link. Just alittle more noise from the valves when using the tuner pro headset. I'm deaf anyway (so my wife keeps telling me) therefore I don't use the headset.
Old 06-24-2007, 09:22 PM   #9
Spec_C
Member#: 91423
Chapter/Region: HIIC
2004 PSM STi on Meth
Tuned by Chris Black@AMS
Spec_C is offline   Reply With Quote
Where is the knock sensor located on an 04 WRX? shinsain Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-09-2009 01:54 PM
2nd Knock Sensor Location, 2nd Knock Sensor Locatoin! SentinelSison UTEC 3 05-24-2006 11:06 PM
Additional Knock Sensor Location - Aftermarket - TXS Tuner Pro crystalhelix Engine Management & Tuning 5 10-11-2005 07:51 PM
Sti - Knock Sensor location dstarcke Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-21-2004 09:44 PM
J&S knock sensor location lotusTT Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-15-2003 01:09 AM
