Old 01-17-2005, 11:14 PM   #1
Airboy
Member#: 72829
2006 WRX
2015 WRX
Default Does the rear window washer nozzle spray or stream?
Does the rear washer nozzles spray like the fronts do? Or, does the washer fluid just stream out like a bad case of runny nose. My '05 RS wagon is doing the latter.
Anyone else find the front driver side wiper smears about 2/3 the way up? Not a streak like from a nick on the blade but it kind of drags a patch of dirty water back across the windshield. Been like that since day 1...
Airboy is offline   Reply With Quote
Old 01-18-2005, 09:11 AM   #2
skyhawk
Member#: 36255
04 WRB WRX
Drive 2 Work,Work 2 Drive
I have never seen a rear washer operate on a car or never had one on a car, but I would think it would have to stream. If it sprayed, then the airflow going over the car and down the back would blow the spray away from the glass before it even reaches the glass. Just my guess though.
As for the front wiper, you may have something on the wiper. I have noticed that when I clean my windshield at a gas station when I fill up, if I use the squeegee on both sides of the blade after I do the glass they work alot better. Gets all of the bug guts off of it if the wiper ever smears the bug guts over the glass. Try that or use something else to clean the blade, or replace them. Just be careful not to use something that will dry the rubber out on the blade.
skyhawk is offline   Reply With Quote
Old 01-18-2005, 09:15 AM   #3
vile
Member#: 32371
'02 t-rex wagon
platinum
the rear wiper nozzle on the wagon is pathetic at best....it just slide down the windshield, as you stated, like two nostrils from a runny nose
vile is offline   Reply With Quote
Old 01-18-2005, 09:24 AM   #4
GuyLR
Member#: 21811
2003 WRX Wag/01 OBS
WRB and SM
The rear wiper mounted nozzle on my '00 OBS tries to stream upwards! It's awful. At least yours streams downward from the top.
GuyLR is offline   Reply With Quote
Old 01-18-2005, 09:45 AM   #5
Vacca Rabite
Member#: 55491
WRX, 1968 Jeep m715,
1976 VW Porsche 914
"Runny Nose" is an excellent description of the rear washer fluid action.
Zach
Vacca Rabite is offline   Reply With Quote
Old 01-18-2005, 02:59 PM   #6
AWDfury
Member#: 29819
02 wrx wagon
sedona red pearl
yup, just streams out over the glass, no even coverage.
AWDfury is offline   Reply With Quote
Old 01-18-2005, 03:09 PM   #7
dead_penguin
Member#: 70368
2005 RS Wagon
I've also got an 05 RS Wagon, and it runs out of the nozzle in two heavy streams as well.
Maybe this is on purpose? I'd imagine if a fine spray was used much of it wouldn't hit the rear window while driving...
dead_penguin is offline   Reply With Quote
Old 01-18-2005, 06:22 PM   #8
makanai
Member#: 65277
2004 WRX Wagon
Platinum Silver
It streams.
I can't complain, mine works like a champ (stream or no). When we got pounded with snow a few weeks ago, my back window was constantly getting covered with salt and slush. The wiper & spray combo did a great job keeping my rearview clean . . . uh, as it were.
I noticed that my front wipers would leave a pretty shoddy patch about half way up where the overlap is. I replaced the blades, now they work fine.
MAK
makanai is offline   Reply With Quote
Old 01-18-2005, 09:10 PM   #9
corrie
Member#: 24069
2013 Legacy
Yeah, mine just kinda runs down the back window...not really a "spray"...basically is worthless because the wiper just throws the water off, doesn't wipe it across at all..
corrie is offline   Reply With Quote
Old 01-18-2005, 09:21 PM   #10
reaubideux
Member#: 33666
I don't think it's worthless. If I keep holding the knob down to keep the fluid squirting while the wiper wipes back and forth it works great. While the wiper is on one half of the window fluid is still squirting and when the wiper comes back to sweep across the other side it pushes the fluid down and spreads it out a little and lubricates the wiper and it does a great job of wiping down the rear window.
Unless you have sap or tar or something on your rear window I have never had a problem cleaning off the rear window using the wiper and fluid nozzle. I don't get how some of you think it is so worthless.
reaubideux is offline   Reply With Quote
Old 01-18-2005, 11:55 PM   #11
Airboy
Member#: 72829
2006 WRX
2015 WRX
I think that is a pretty good guess. Although , if it was a pressurized stream rather than the "runny nose", I wouldn't have hold it in the "spray" mode for like 5 seconds to get enough fluid to clean the window. The front washer nozzles on my '95 Integra was like that, focused streams rather than sprays. Oh well, at least now I know it is "normal".
Old 01-19-2005, 02:21 AM   #12
AWDfury
Member#: 29819
02 wrx wagon
sedona red pearl
i think i bought too big of a replacement, it doesnt lie flat. any idea what the size is for the rear wiper?
Old 01-19-2005, 08:42 AM   #13
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
Pretty sure the rear wiper on the wagon is 16". At least I think thats what I put on when I replaced it. Easiest thing to do, get a tape measure and measure the length of the old one.
coyote73176 is offline   Reply With Quote
Old 01-19-2005, 09:33 AM   #14
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
*wants a rear wiper for his coupe*
WTB: Window washer nozzles aspen_rex Private 'Wanted' Classifieds 1 03-05-2009 12:11 PM
in a sedan, can you wire up the rear window washer? idealrides Electrical & Lighting 6 03-28-2004 01:43 AM
winshield washer nozzles spray with too much force? SpeedShift Newbies & FAQs 13 10-12-2003 04:07 AM
