Old 01-18-2005, 01:26 AM   #1
WolfInSheepsCLothing
Member#: 61197
2004 WRX
vf39 + goodies...
Default 2nd thoughts about installing my turbo inlet hose...
mods on my '04 WRX:
BPM tt-series TBE
STi uppipe
K&N panel filter
Cobb's AP stage 2 (hwy map)
i got a good deal on a Samco turbo inlet hose. cobb's website says you need to use the stock intake with stage 2 maps, but nothing about the inlet hose. if the uppipe is within the parameters of the mapping, would it be safe to assume the same for the inlet hose?
i've searched and searched, and found a lot of different opinions that the car would run anywhere from "within parameters", to substantially leaner with the aftermarket hose.
would it be safe to install with cobb's AP? should i just hold off for a while until i can get a dyno-tune? sheesh, maybe i'll just save for an STi l
WolfInSheepsCLothing is offline   Reply With Quote
Old 01-18-2005, 01:28 AM   #2
Diabolical1 CC
Member#: 59897
See the turbo thread.
Diabolical1 CC is offline   Reply With Quote
Old 01-18-2005, 08:35 AM   #3
subieworx
Member#: 47769
Why not call Cobb?? They would be able to give you the definitive answer. That's their job.
subieworx is offline   Reply With Quote
Old 01-18-2005, 09:39 AM   #4
tpc01x
Member#: 68691
2004 S2000
GPW
I'm running a perrin turbo inlet, with a apexi short ram, and a cobb stage 2 map, If anything its still slightly running rich.
fyi: its a PITA to install the hose.
tpc01x is offline   Reply With Quote
Old 01-18-2005, 05:41 PM   #5
xtorted-legacy
Member#: 19568
1995 Impreza L
Brilliant Red
the inlet isnt going to make a huge difference. It will help spool, but its not going to alter any characteristic enough to warrent worrying. The samco just has a smoother inside then the stock peice. Put it on and go have fun.
xtorted-legacy is offline   Reply With Quote
Old 01-18-2005, 07:43 PM   #6
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
You got that right.
wrx05 is offline   Reply With Quote
How To: Install a Turbo Inlet hose? mhwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-28-2008 04:25 PM
I put a hole in my turbo inlet hose! MF-DIF Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 01-06-2007 06:06 PM
Just installed Perrin turbo inlet hose on friend's car txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-10-2006 12:53 AM
HELP! broke my turbo inlet hose off at the recirc. hose connection metbluWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-29-2004 11:27 PM
to those that have installed silicone turbo inlet hoses... wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-21-2004 08:06 PM
