Old 01-18-2005, 03:57 AM   #1
elhalisf
Member#: 56332
2005 STI Cobb Stg 2
Default Airbag light problem, on, off, on off....
Well I got a 2004 WRX. I bought it salvage, replaced the airbags, but not the module at first. Had the airbag light on for 6 months. The light started getting on my nerves so I bought a new module for it about 1 month ago. This took care of the light for about 3 weeks. A couple of days ago the airbag light went back on. So I drove with it on for about 30 minutes to my destination, before I turned off the car, it was gone. Parked it for the night. No light when I fired it up in the morning. I stopped by Home Depot for about 20 minutes, and when I started it this time, the airbag light is back on. After about 20-30 minutes driving, it dissappeared again.
So pretty much I have noticed, whenever I turn the car off for less than an 1 hour before I fire it back up again, the airbag light is on. After about 20-30 minutes of driving it dissappears. I tried turning the car on and off to make it dissappear but that didnt work.
Any idea what is going on?
elhalisf is offline   Reply With Quote
Old 01-18-2005, 07:24 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Does the light come on when you turn the wheel, and when the light is on does the horn stop working? The clock spring/roll connector assembly in the steering column is probably bad if the airbag deployed and you didn't replace the connector.
There is a procedure in the service manual for reading codes from the airbag module, if you follow that you can get a better idea what is wrong but if you have the symptoms above you need the roll connector.
Old 01-18-2005, 02:49 PM   #3
elhalisf
Member#: 56332
2005 STI Cobb Stg 2
The roll connector, black ring with yellow type of wire comming out, was replaced. I didnt check if the horn worked while it was on or not but will definitely do that the next time. What I am confused about is why is it working at one point and not at another, just after I shut off the car for 20 minutes and turn it back on.
Turning the wheel doesnt affect the light at all.
Old 01-20-2005, 01:05 PM   #4
burton1181
Member#: 79870
02 WRX
I am expierencing the same thing with my 02 WRX I don't know what to do about it. I didn't notice at first but I re-mounted my turbo timer and I noticed that the air-bag light was on... do you guys have any suggestions?
burton1181 is offline   Reply With Quote
Gauge / Airbag light problem Bigbadwolf Electrical & Lighting 0 08-21-2009 04:08 AM
Airbag light problems in a dash swapped car psyber_0ptix Electrical & Lighting 0 06-24-2009 12:19 AM
Airbag light problem markadopolus Service & Maintenance 14 07-22-2005 08:05 PM
Airbag light problem. still coloradosti Electrical & Lighting 1 07-05-2004 08:07 PM
airbag light problem?? Blitzwrx Electrical & Lighting 3 01-16-2004 06:26 PM
