View Poll Results: radiator options?
repair broken pos cuz it's cheap 0 0%
replace w/stocker, who needs the added expense 1 33.33%
go aftermarket, might as well go big 2 66.67%
Voters: 3. You may not vote on this poll
Old 01-18-2005, 09:41 AM   #1
vile
Member#: 32371
'02 t-rex wagon
platinum
Default radiator replacement options
ok, looks like i got the dreaded leak between the plastic end tank and the core. it's extremely slow, so i'm not in a big rush for a new radiator. questions are, can it be repair? if so, is it worth the cost to repair?
if not repair, should i get another stocker(from an '03)? this would provide the easiest route as it's a direct drop in. iirc, it's the cheapest of the radiator as well.
or should i fork out some extra cash for an aftermarket, something like a speed monkey or a koyo? this would cost more, but would be better overall for my cooling system. however, i do not have, nor do i plan on ever reaching power level which requires this extra cooling capability. i'd only be doing for piece of mind.
btw, can't go to the dealer on this one, pasted my warranty period...me's '02's got 75k miles.
vile is offline   Reply With Quote
Old 01-18-2005, 10:42 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
I just went with a Speedmonkee unit when my radiator started to show signs of leakage. You get better cooling performance with an aftermarket radiator. . .especially if you have a modified engine.
Calvin
cnk is offline   Reply With Quote
Old 01-18-2005, 10:33 PM   #3
strohausii
Member#: 26770
'02 WRX
midnight black
I think I've seen Kyoto or Koyo (sp?) all aluminium radiators for ~$370 (group buy), most of these plastic end tank radiators have a max life of 10 years before they start cracking at the main hose connections.
strohausii is offline   Reply With Quote
Old 01-24-2005, 01:58 AM   #4
20024door
Member#: 80174
I like the pwr mine is great
20024door is offline   Reply With Quote
Old 01-24-2005, 06:58 PM   #5
WRXcer
Member#: 58059
2002 WRX Wagon
My MRT radiator works well.
WRXcer is offline   Reply With Quote
Double DIN Replacement Options seigniory Car Audio, Video & Security 39 11-01-2004 10:07 PM
MY96 clutch replacement options and questions?? crk4 Transmission (AT/MT) & Driveline 1 11-19-2003 07:05 PM
Front strut replacement options tripm Brakes, Steering & Suspension 2 07-12-2003 10:28 PM
Who has had their radiator replaced or has one that leaks corallo99 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 03-31-2003 11:43 AM
Rear bumper replacement option. Miracle Worker Interior & Exterior Modification 16 11-26-2001 02:51 PM
