Old 01-18-2005, 02:40 PM   #1
Matrix 1193
Member#: 68286
2006 WRX STI
Pearl White
Default aftermarket battery
its cold, my car has big amps, MTXThunder1004 and JL Audio 500 D block to be specific, and I am running Hydra EMS, which I think is not as energy efficient as the stock ECU because it seems to drop my battery voltage during crank to a low 9 voltz. What brand of aftermarket batterys do you guys run, probably competition grade. The car is a 2002 WRX. And also if you guys are running beefed up alternators, any links on this?
thanks
Matrix 1193 is offline   Reply With Quote
Old 01-18-2005, 03:00 PM   #2
949
Member#: 58906
opitma blue is best .
optima yellow is great.
949 is offline   Reply With Quote
Old 01-18-2005, 03:38 PM   #3
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Any of the Optima batteries are a good choice IMO. Some people feel they are pricey though and cheaper batteries like Orbitals are just as good if not better. Search for Optima on here and you will find one thread that has plenty of good info. Also I really like www.remybattery.com for the prices.
offset
offset is offline   Reply With Quote
Old 01-18-2005, 03:46 PM   #4
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Optima 35R Red should be sufficient for you...although, if you like to keep the radio on without the car running, then the Optima Yellow would be better for your application.
Hank3 is offline   Reply With Quote
Old 01-18-2005, 07:12 PM   #5
Matrix 1193
Member#: 68286
2006 WRX STI
Pearl White
I measured the Optima's size and it wont fit in the sleeve, you guys have no problem mounting them? I ended bying an Autocraft Titanium instead of the optima yello which was like 160. Everytime i trie to look up batteries for the MY02 WRX the optima doesn't come up as an option.
Old 01-18-2005, 07:28 PM   #6
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
That's because you need the reversed terminals to fit, IE the 35R.
tooocool49723 is offline   Reply With Quote
Old 01-18-2005, 07:59 PM   #7
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
you need to buy it from remybattery or tna-sports. Those are the only places that I have seen the reverse terminals.
The beauty of the Optima is that there is no maintenance. Just install it and go.
wrx05 is offline   Reply With Quote
WTB: aftermarket battery dire Tri-State Area Private Classifieds 0 12-01-2007 11:26 AM
WTB: Aftermarket Battery Tie Down Rippen Griffen MAIC Private Classifieds 4 10-12-2007 02:51 PM
aftermarket battery NewSTI Electrical & Lighting 0 09-30-2006 07:14 AM
What is the best aftermarket battery? MotorCity Electrical & Lighting 14 07-14-2005 02:04 AM
Let's talk aftermarket batteries jblaine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-03-2003 01:52 PM
