Old 01-18-2005, 04:56 PM   #1
bin04
Member#: 63913
2004 STi (not STI)
wrb
Default Help! engine knock after installing Vishnu stage I
Finished installing Vishnu stage I last night on MY04 wagon, and it would appear I have some knocking going on. Here is what got put in:
uppipe
downpipe
exhaust
pulley
Vishnu ECU programmed for stage I has been installed and running in 'valet' mode for a while with no knocks with everything stock. After installing the above, knocking seems to be present in both modes.....
installed the mechanical CEL fix for the rear O2, and the resistor for the EGT.
No exhaust leaks, no CELS, nothing obvious. idles fine, etc.
Suggestions?!? What should i be looking at?
bin04 is offline   Reply With Quote
Old 01-18-2005, 05:25 PM   #2
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
first i've heard of Vishnu cars knocking.....all the rest seem to be Cobb.
Drews_WRX is offline   Reply With Quote
Old 01-18-2005, 05:44 PM   #3
Borti
Member#: 74403
you must live in some dirty hole then.
Borti is offline   Reply With Quote
Old 01-18-2005, 05:54 PM   #4
cnk
Member#: 10757
2013 BRZ Limited 6MT
Did you call Vishnu yet?
Calvin
cnk is offline   Reply With Quote
Old 01-18-2005, 06:12 PM   #5
bin04
Member#: 63913
2004 STi (not STI)
wrb
sent an email. was looking for youse guy's perspective/wisdom, as well. :-)
Old 01-18-2005, 06:36 PM   #6
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
Enlighten me all mighty one......
<--Cobb stage 2
Old 01-18-2005, 08:19 PM   #7
cnk
Member#: 10757
Give them a call as they respond much better to phone calls then to emails.
Calvin
Old 01-18-2005, 08:24 PM   #8
bin04
Member#: 63913
2004 STi (not STI)
wrb
will do. thanks!
Old 01-18-2005, 08:24 PM   #9
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
Calvin
finnRex is offline   Reply With Quote
Old 01-18-2005, 08:42 PM   #10
antimullet
Member#: 44193
2008 WRX STi
So explain why you say you're getting knock?
Sure the downpipe ain't slapping around?
antimullet is offline   Reply With Quote
Old 01-18-2005, 09:29 PM   #11
bin04
Member#: 63913
2004 STi (not STI)
wrb
This was a Vishnu stage I pulled from a friend's 04 wagon.... ECU was:
tuned for colorado (altitude and lack of octane) and the exact setup (Vishnu uppipe and TBE).
Have not ever had Det on this car before, even with the Vishnu ECU in the car running in low boost or 'valet' mode on stock exhaust.
Iam not running colder plugs!! I didnt realize this setup required 'em!! Dang. Actually, I should check with my friend and see if he had colder plugs when the setup was in his car.. Might this be it?
As far as how i am surmising that i am experiencing Det? Hearing the detonation (pinging or rattling) under load at mid to high rpms. Low rpm doesn't APPEAR to be having the prob. - ie. i can't hear what seems to be det. Seems to be worse the warmer the car is as well - better at the low end of warmed up and worse after driving it for a bit..
Mechanical Engine Knock After Car Is Warmed Up buzz313th Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-26-2013 09:10 AM
Help! Engine misfire after boost gauge install... wrxsomeday Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 09-16-2009 06:25 PM
Soliciting help to install Vishnu Stage 0 and Turbo-back exhaust sdseagles South East Region Forum 17 03-31-2003 12:43 AM
Engine Knocking after CAI intall? ChinkyWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-13-2002 02:43 AM
Where to install Vishnu Stage 0 Sauceboy01 Southern California Impreza Club Forum -- SCIC 4 01-22-2002 01:58 AM
