Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 01-18-2005, 05:28 PM   #1
Mikemar
Member#: 7259
2004 Sti
Stone Chip Blue
Question Plugs and Wires
Well I've looked around and searched here but I cannot find what the part number for the stock NGK plugs in the Sti. I know they are Iridium but NGK lists a platinum plug for the Sti on their web site. A have about 58K so I guess its time to change them. Since I'll be down there I suppose I should change the wires also. My dealership wants over $500 bucks for this. They said the plugs were $25 each and then another $100 to install them. They also said that they need to remove the intake plenum to change them so its a real pain for me to do myself. ANDDD they also said the wires were special wires and that each one has its own coil pack in the boot that attaches to the plug. How much of all this is BS.?
Mikemar is offline   Reply With Quote
Old 01-18-2005, 05:40 PM   #2
Tobey
Member#: 21400
2015 WRX Limited
ISM
remove the intake manifold? you need to go to a different dealer. the plugs are on the sides of the engine, the intake manifold is on the top!!
plugs are very easy to change, maybe an hour tops. i'm not sure if there is a need to change each coil-pack. can anyone chime in on the recommended mileage for that change?
Tobey is offline   Reply With Quote
Old 01-18-2005, 05:40 PM   #3
apoji187
Member#: 64636
04 STI
they are special wires, in the fact that they attach to the coil pack. its not like a distributor ignition system.
Over each plug, there's a coil pack (coil over ignition) which has to be taken off to access the plugs. You do have to take off the airbox, windshield washer resivour, and battery to get at everything.
apoji187 is offline   Reply With Quote
Old 01-18-2005, 07:17 PM   #4
pestysti
Member#: 52765
2004 STI
what he said i did this same thing last night not to much of a pain JUST make sure you have a rachet with a pivot head makes things a lot easier
tools i used
pivot rachet, 1 1/2 in ext and the 4in ext good plug socket
Dustin
pestysti is offline   Reply With Quote
Old 01-18-2005, 07:17 PM   #5
Mikemar
Member#: 7259
2004 Sti
Stone Chip Blue
Thanks, that what I thought. How about part numbers and what kind of wires are good?
Old 01-18-2005, 07:37 PM   #6
CreoWRX
Member#: 19024
2014 Audi S6 + APR
Glacier White
As stated before, you don't need "wires". If anything is faulty, you replace the whole coil pack.
Can I Buy Plug Wires For My WRX?
-Mike-
CreoWRX is offline   Reply With Quote
Old 01-18-2005, 07:43 PM   #7
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
How about searching and posting in the right forum?
Old 01-18-2005, 07:56 PM   #8
Mikemar
Member#: 7259
2004 Sti
Stone Chip Blue
If you read my 1st post it says that I did search, didn't find the stock numbers though, just for colder plugs. So I guess the 2.5l forum is just for modified cars? Because everything else would be considered some kind of service.
So what you guys are saying it that I have to get the stock wires from the dealer then?
Old 01-18-2005, 08:41 PM   #9
kevinsUBARU
Member#: 2263
2012 Impreza Sport
uh, did you read the owners manual? there should be manufacters part numbers listed in the specifications. Don't worry about the wires. If you are though, get a multimeter and periodically check the resistance of them. If it gets too high, get new ones.
kevinsUBARU is offline   Reply With Quote
Old 01-18-2005, 08:51 PM   #10
Mikemar
Member#: 7259
2004 Sti
Stone Chip Blue
I guess I worded my original post wrong. I have the part number for the plugs but just can't find then anywhere and $25 each from the dealer seems crazy. I was concerned about having to disassemble my engine to replace the plugs and wires. I have 60K on the car so I thought it was time to change the wires too.
Old 01-18-2005, 09:23 PM   #11
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
If $25 is bad, wait till you have to get new brake pads!
Read the Spark Plug FAQ at the top of this forum and it should explain to you why they are so much and the other than stock options. I can put exactly 873 different plugs into my WRX, you have exactly 3 options.
Old 01-19-2005, 05:39 AM   #12
Mikemar
Member#: 7259
2004 Sti
Stone Chip Blue
As a matter of fact I just bought new pads. $180 for front and rear EBC green stuff pads, less than half of what they wanted for the stock pads at the dealer.
Old 01-19-2005, 03:43 PM   #13
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
There are no wires to replace. Just go buy new plugs. The only time you would ever have to replace a coil pack is if it isn't working, and the ECU will trigger a CEL for that. Just make sure to gap the plugs even if the sales guy says that you don't need to.
Plugs should be $2 a piece at Murrays/Auto Zone/ etc for NGK platinums.
mbiker97 is offline   Reply With Quote
Old 01-19-2005, 05:33 PM   #14
Mikemar
Member#: 7259
2004 Sti
Stone Chip Blue
But I thought they had to be Iridium?
plugs and wires and fluid time? Oh my! Kev5n24 Baja Forum 20 06-26-2007 11:17 AM
Spark plugs and wires soccer_freak_m@hotma Normally Aspirated Powertrain 26 01-18-2004 12:12 PM
Need New Plugs and Wires Any Suggestions Zephyr Normally Aspirated Powertrain 5 03-07-2001 12:03 AM
Spark Plugs and Wires? Steven Saunders Normally Aspirated Powertrain 15 02-02-2001 12:19 AM
