Old 01-18-2005, 09:25 PM   #1
elcorazon01
Member#: 73988
Question JDM cluster swap
I am planning on swapping a 96 JDM cluster into my Impreza of the same year. The question I pose to you all is this: are there any modifications I need to make other than just getting used to the kmph. For example how does the coolant temp gauge work since I'd imagine the JDM measures temp in C and the gas gauge is probably measured in liters? Or is that not the case? Anyway, any info would be great. Thanks.
Andy
elcorazon01 is offline   Reply With Quote
Old 01-20-2005, 02:00 PM   #2
burton1181
Member#: 79870
02 WRX
It works the same way, what I do is just remember that 160 is 100 and half of that is 80 so 50mph. Adjust accordingly... Iam sure the coolant temp gauge works in C but that gauge still acts the same way. When you first start it up it will probably be a little higher then normal but thats ok. Gas works the same way. Hope that helps.
Chuck
burton1181 is offline   Reply With Quote
JDM STI cluster swap. Need Info cppchrisdh Subaru Conversions 1 02-01-2007 02:32 PM
JDM STi 05 Cluster swap ??'s banzai Electrical & Lighting 7 12-19-2006 10:25 PM
Who makes the harness for the bug eye usdm to jdm guage cluster swap? S14guy Subaru Conversions 1 03-01-2006 11:02 PM
cluster swap - 03 -> sti or jdm v7 cluster djcttb Interior & Exterior Modification 4 02-08-2006 06:08 PM
JDM STi Cluster Swapping PinoCchiOy Electrical & Lighting 7 09-24-2004 06:59 PM
