Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 01-18-2005, 08:47 PM   #1
jlee8196
Member#: 22211
Default Hydra autotune under 2Krpm & LTT
After couple weeks of tuning, my fuel map is very on target, I had to lean out
a conservetive base map. but since autotune tune above 2k rpm. I have a cut off under 2K with a sizable bump. I tried leaning it out a little, but don't really know how much. Is there a way using the auto feature other then logging and manually tune it.
Also what Long term fuel trim use for. Why it's not used under wideband sensor?
jlee8196 is offline   Reply With Quote
Old 01-19-2005, 01:41 AM   #2
jlee8196
Member#: 22211
I just read the element tuning guide, I think I'd understand how to tune the rest.
But.
How long does it take to learn LLFT Under closed loop. Do I need to upload and then download to save the changes made?.
Old 01-19-2005, 12:05 PM   #3
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
While using "closed loop and Long Term Learning" 14.7 AFR, short and long term fuel trims are made during the drive cycle only. Once you turn off the car those changes are lost (they are temporary). There is no need to upload/download while using "closed loop" only if you are using "autotune."
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
hydra - misfire under full load MobbDeep222 Other Engine Management 22 10-20-2009 11:17 AM
Hydra autotune..? please help ddd555 Other Engine Management 8 09-02-2008 12:22 PM
Hydra 2.5 VSS & Ratio ddd555 Other Engine Management 2 09-02-2008 12:05 PM
hydra autotune - jpgs of it in action DarthChicken Other Engine Management 18 04-26-2005 09:09 PM
