Old 01-18-2005, 09:04 PM   #1
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Exclamation Tuner Pro WBO2 not working...!!
Well after being gone for six months on deployment, i come back and drive my car for a little bit. The tuner is working perfect, the wb02 reading just fine. Well I relocated the tuner to below my stereo, it was wedged inbetween the ebrake and the passenger seat. Well now the tuner will count down, and sometimes i get a reading from the sensor and then it says Err and sometimes it goes strait to Err without reporting any afr at all. Its weird because sometimes it works for a few seconds, and sometimes it doesnt work at all. It used to work 100% of the time, not a single problem. I have always been careful with the sensor, and I was even able to do a free-air calibration, but then it still would fault out sometimes. I did FAC after updating it to the newest software revision.
Does anybody know what could cause this problem? Any suggestions would be awesome, i really dont like my new toy not working!
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 01-19-2005, 07:25 AM   #2
TurboXS (Pete)
Member#: 16704
Hook your laptop onto the Tuner to see what error has been reported.
regards
Pete
(TurboXS)
TurboXS (Pete) is offline   Reply With Quote
Old 01-19-2005, 08:02 AM   #3
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Ok. Last time i checked that it says "sensor malfunction" i believe. I'll check again though just to double check. Just so you know, its the bosch sensor.
Jeff
Old 01-19-2005, 04:41 PM   #4
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Pete,
The tuner says "Disconnected". It is plugged in, so something else is wrong. I have it off the car and dangling in the air off to the side of the car at the moment. I am going to try to reflash it to 1.5 again and see if that fixes it. It worked with the old software but i couldnt find that anywhere so i cant go back to it.
Jeff
Old 01-19-2005, 06:07 PM   #5
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
If it helps....The sensor does not warm up at all, at least the outside doesnt. It is totally cool to the touch. The sensor was plugged in for the first time a long time ago, worked fine, and started doing this "disconnected" thing without ever being unplugged so its not like i unplugged it and broke something. I checked the voltages on the pins that go into the sensor plug. THey were something like 7, 12, 3, 3 7 or very close to that. I hope thats right. If you want I can go check them again and tell you what color had what voltage.
Jeff
Old 01-20-2005, 03:54 PM   #6
TurboXS (Pete)
Member#: 16704
Sounds like the heater circuit is broken somewhere. The heater wires on the Bosch connector are (+) grey and (-) white at the Bosch sensor end.
Disconnect the sensor from the cable.
Measure the resistance between these pins to the sensor. The resistance should be less than 4 ohms.
Connect a voltmeter to the pins of the Tuner cable that correspond to these pins. Power up the Tuner and you should see a voltage starting about 7V and increasing to about 11V as the Tuner countdown reaches zero.
The software revision should have no effect on the operation of the sensor.
regards
Pete
(TurboXS)
Old 01-20-2005, 04:36 PM   #7
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
I will go check that right now and post what i find. Thanks for your help Pete.
Jeff
Old 01-20-2005, 05:09 PM   #8
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
The resistance is 3.8 ohms.
The voltage is 12.9. I know that is kinda high. I tried to adjust the input voltage in the settings to see if raising the number would cause the heater voltage to drop a little lower but it didnt. I raised it to 18v input and saved, then turned it off then back on and still got 12.9 volts. So i went to put it back to 12.9 and when i hit ctrl-s to save the settings back it froze(the tuner, not the laptop) and i was unable to get back into it. I tried turning the car on and off several times but the tuner now shows NOTHING on the front display, and does no countdown. The only thing it does is immediately light up the green led on the front. I now only get like 2v on the heater wire. The tuner pro basically just crapped out on me.
I hope this helps, and i wish i was provided a link to download the old firmware.
Jeff
Old 01-21-2005, 04:47 PM   #9
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Bump....Any ideas? I think i need to reflash it either way, now i cannot even get to the utec through it.
Jeff
Old 01-22-2005, 11:27 AM   #10
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Just to be clear, all these problems occured AFTER updating to Version 1.5. Before that, i had zero problems, ever.
If anybody else has ever had problems due to the new version, please post so maybe i can figure out what to do.
Thanks,
Jeff
Old 01-22-2005, 11:04 PM   #11
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
bump....still nobody? I am kinda in a jam here. I am in desperate need of a good tune...
Jeff
Old 01-23-2005, 04:48 PM   #12
cpturbo
Member#: 49175
2004 STI
Default Tuner problems
no message
cpturbo is offline   Reply With Quote
Old 01-23-2005, 09:17 PM   #13
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
I am out at sea right now but i'll be back probably saturday so at that point im going to reflash it with the software that TurboXS sent me.
cpturbo - thanks for your offer, i'll call you when i get back in town.
Jeff
Old 01-23-2005, 09:38 PM   #14
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Just curious, what are the versions of the firmware for the Tuner? Starting with what they came with, which i believe is 1.1. Were there any versions between that and 1.5? if there was then i somehow missed them, maybe they came out when i was out on deployment for 6 months or something.
Anyways, to make a long story short, what were all the versions and what did they add, in a nutshell?
Jeff
Old 01-23-2005, 10:03 PM   #15
cpturbo
Member#: 49175
2004 STI
There is a version 1.3 that fixed synchrony with the UTEC. I like version 1.5 but it is giving me the same problems. I can not access the menu with the 1.5. By the way, when calibrating the sensor. You may have to have the car on so that there is enough voltage with the sensor in free air only.
CPTurbo
Old 01-23-2005, 10:25 PM   #16
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Intersting..i never had any problems with synchrony, not that i can remember at least. Ok well thanks for that tidbit of info. I hope thats the version that was sent to me(1.3). If its 1.1 then thats fine too cause thats what im used to anyways.
Jeff
Old 01-23-2005, 11:58 PM   #17
cpturbo
Member#: 49175
2004 STI
I guess what I meant was that it helped eliminate a bug in logger 1 on UTEC. No real synchrony issue. sorry for the confusion.
CP
Old 01-24-2005, 09:15 PM   #18
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Well my wife tells me that i was sent version 1.4. I think thats kinda funny because nobody mentioned what is special about that version over 1.3. Anybody have any words about 1.4? I hope it works on my tuner, thats all i can say. Man i really cant wait to get home and get my car tuned...being out at sea SUCKS!!!
Jeff
Old 01-25-2005, 09:29 AM   #19
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
jeff, please keep us posted as to how it works out.
good luck,
ken
Old 01-31-2005, 03:45 PM   #20
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
OK Here is an update.
Reflashed it to 1.4. Did the EXACT same thing.
Reflashed it to 1.3. Did the EXACT same thing.
Reflashed it BACK to 1.5. Things get interesting.
At first it did the exact same thing again, so i unplug the harness from the back of the tuner while its on, then plug it back in. It does the count down and when its done, instead of saying "Err" it indicates >25:1 because its in free air, so im like "YES it works!" The WB02 sensor would now heat up. Moments later the tuner shows "FR.A" so it recognizes that its in free air, which is good. So i unplug it and reinstall it back into my dash below my stereo and i test it again before actually screwing the thing into the dash, so its there exposed still. I try it one more time to make sure its good and it shows >25:1 for about 4 seconds, then it rushs down to around 18:1(taking about 2 secs to do so) then shows "Err" and says the sensor is disconnected. I tried unplugging it many times and trying turning the car off, wiggling the plugs and everything but nothing works, now it doesnt work anymore, it just shows >25:1 for about 4 seconds then shows Err.
All in all this has been a pretty cruddy day and the tuner is absolutely not working. I am seriously like an inch from throwing it in the trash can and never looking back because thats all it is, a paperweight.
If anybody has any suggestions please clue me in before i go crazy.
Jeff
Old 01-31-2005, 04:01 PM   #21
TurboXS (Pete)
Member#: 16704
Open up the D-type connector and check for any damaged or broken wires. Examine the contacts both on the Tuner and the 15 way D-type for signs of pins being pushed back or bent.
regards
Pete
(TurboXS)
Old 01-31-2005, 04:02 PM   #22
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
I have checked the back of the tuner and the pins are all perfectly strait. I can look inside the d-type connector but i dont think i'll find anything... i'll post what i find in a little bit.
Jeff
Old 01-31-2005, 05:00 PM   #23
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
OK well heres what i found...
All wires but one checked out perfect.
The black wire that goes into the pack of 3 wires is slightly exposed(its own insulation is missing) for about 1/4 of an inch before it dissapears into the grey wire jacket for those 3 wires. It looks like a cable shield wire but i dont know.
Here's something i think i've nailed it down to:
When the cables comming right out of the d-type connector are bent/curved 90 degrees to the left side of the tuner, the tuner will work fine. If they come out of the d-type and continue on away from the tuner in a semi-strait manor, the tuner will Err out.
It looked like everything was ok inside the connector but all fingers point to it as the culprit.
Any ideas?
Jeff
Old 01-31-2005, 05:38 PM   #24
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Its affirmative, when the cables from the d-type are pulled to the left the tuner works fine and when they arnt it shows "Err". I just reinstalled the wbo2 back into the downpipe and started up the car and it works perfect.
Crazy huh....
looking for repatable tuner / pro shop to do motor work ScooByBooSt007 Built Motor Discussion 3 05-09-2010 08:44 PM
OS Tuners with WBo2 sensors: What if I mount sensor AFTER cat? saab-on-the-cobb Open Source Reflashes 7 07-18-2009 10:49 AM
Need replacement Tuner Pro Bosch WBO2 sensor.. suggestions? AaronWRX UTEC 23 07-28-2008 07:10 PM
TurboXS TUNA Pro WBo2 FS meld Engine/Power/Exhaust 1 12-30-2006 02:48 AM
UTEC and Tuner not working together TravisSTi UTEC 3 03-04-2006 01:16 AM
