Old 01-19-2005, 08:29 AM   #1
leeklimala
Member#: 75128
1991 Legacy L
Charcoal Grey
Default Frothy Orange Goopy Liquid
In eastern NC, below freezing, 91 Legacy, 2.2, auto, started it this morning, heard a pop and fizz coming form under the hood, went to check it out...FROTHY ORANGE GOOPY LIQUID coming from the left side of the engine. Didn't have time to decipher exact location, had to snag a ride to work from my neighbor. OIL? COOLANT? Sometimes the PS dosen't work until I get going down the road, any Ideas? this is My dad's spare car, and I am driving it until my Super Coupe gets fixed. I know a little about this car but not much so please be specific if you reply. Thanks.
Lee
leeklimala is offline   Reply With Quote
Old 01-19-2005, 09:52 AM   #2
sha_zapple
Member#: 41012
1998 Legacy L
My name is Lee also, cool
Id guess its power steering. Oil is black/brown, coolant is usually green. Check the PS resevoir.
sha_zapple is offline   Reply With Quote
Old 01-19-2005, 10:41 AM   #3
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
my guess is oil(might be kinda orangish if mixed with coolant or other fluid or in small quantities), power steering fluid, or brake fluid.
although this may not be the issue because the oil is usually black, I'd check the CV boots too. Hope and pray its them because their cheap But often when they break the oil from the boot goes flying everywhere.
can you be more exact as to where its bubbling out? that would help an incredible amount.
fibuz
fibuz is offline   Reply With Quote
Old 01-19-2005, 12:04 PM   #4
leeklimala
Member#: 75128
1991 Legacy L
Charcoal Grey
small bubble coming from oil pool on passenger side valve cover. ps resevoir had fluid in it but also looked like it had overflowed. the fluid is a light orange color, like new motor oil but the car hasn't had an oil change in over 2000 miles. didn't have time to check oil level. car cranks and runs fine but there seems to be no PS. could the lines get frozen or clogged, possibly pinched anywhere? I could only think the fluid would get frothy if it was being pressurized and sprayed out of a small leak somwhere. No signs of coolant in the puddle, how much PS fluid is in these cars? There is a considerable amount of fluid on the ground, I'd say at least 1 to 2 qts. how hard are the VC gaskets to repace on these things?
Old 01-19-2005, 02:45 PM   #5
mvstype
Member#: 4736
95 12 sec. Legacy
Same Color as a Booger
Could be head gasket. When the gasket goes coolant and oil make a orange froth in the radiator and engine.
MV
mvstype is offline   Reply With Quote
Old 01-19-2005, 08:43 PM   #6
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
Some coolant is orange in color. I think it's environmentally friendly or pet-safe stuff, not positive though. When the car is cold, remove your radiator cap and see what color the coolant is. If you can't tell, add a little water, and gently squeeze the upper radiator hose. This will force coolant up towards the top, where you can see the color.
1-2 quarts? Seems like a lot. Our cars use ATF for power steering fluid, which is usually red in color. Frothy red ?= orange? Or water + ATF = orange? I'd agree with sha_zapple, sounds like PS fluid.
Good luck!
Aaron
fastenova is offline   Reply With Quote
Old 01-28-2005, 03:10 PM   #7
leeklimala
Member#: 75128
1991 Legacy L
Charcoal Grey
It was PS fluid. My dad had put the Penzoil power steering fluid in there and I assume that was wrong. Here is what the pump ended up looking like.
[IMG]Pump 1[/IMG]
Well the PS pump split all the way around the housing.
Last edited by leeklimala; 01-28-2005 at 03:11 PM. Reason: Can't get the dang picture to load
Old 01-29-2005, 05:22 AM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Not sure about that generation of Legacy, but newer ones use ATF in the PS system, not PS fluid. Actually, from what I've seen very few modern cars still use PS fluid, almost every car I've dealt with uses ATF.
Pat Olsen
'97 Legacy 2.5GT sedan
Dog hurt her eye and now its all goopy WrxWonderWagon Off-Topic 5 02-01-2009 05:40 PM
Fatty haters, prepare to get FROTHY! Strider Off-Topic 25 10-30-2006 04:37 PM
Great, I just shot a frothy load all over my pants. rogue Off-Topic 28 02-22-2006 09:35 AM
Nair for men goopy edition vs. roll on Full_Clip Off-Topic 40 06-11-2005 04:50 PM
Bubble/Frothy Trans Fluid SPeeDSiN Transmission (AT/MT) & Driveline 1 07-15-2002 05:36 PM
Message Board Statistics All times are GMT -4. The time now is 02:46 AM.
