Old 01-19-2005, 12:31 PM   #1
toddbrowne
Member#: 79843
Yellow
Question '02 WRX won't start
I've got spark and fuel pressure but no combustion. New MAF, crank and cam sensors. Even starter fluid doesn't get a pop. Ideas?
toddbrowne is offline   Reply With Quote
Old 01-19-2005, 12:37 PM   #2
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Has any work been done on the car recently? Anyone mess with the timing belt or anything like that? Did anyone take off the intake boots?
I guess they had to to replace the MAF. Start there. Look at all the ducts going to the MAF and the intercooler and stuff. If air doesn't pass through the MAF, you won't get fuel to the cylinders.
Where are you squirting starter fluid?
OneOBS is offline   Reply With Quote
Old 01-19-2005, 01:00 PM   #3
toddbrowne
Member#: 79843
Yellow
Repalced MAF because prior performance issues suggested it was faulty. Replaced other sensors out of desperation. Engine has less than 2k on it. Checked intake boots, all secure. Squirted fluid in hose behind airbox lid, re-attached lid. Immediately prior to no-start heard rattle or ping under any load. Timing belt not touched and is intact.
Old 01-19-2005, 01:23 PM   #4
OneOBS
Member#: 63076
2004 Outback Sport
Red!
If it ran before you replaced the MAF (albeit poorly), trying putting the old MAF back in.
Old 01-19-2005, 01:52 PM   #5
toddbrowne
Member#: 79843
Yellow
Didn't replace it until after no start. Thinking I should check valve timing. Seems like a stretch but nothing else adds up. After all the cranking, plug 1 isn't wet with fuel either. Haven't checked others yet.
Anyone know a good, honest WRX mechanic in San Jose?
Old 01-19-2005, 01:58 PM   #6
OneOBS
Member#: 63076
2004 Outback Sport
Red!
I guess your timing belt could've slipped. A compression check will provide some info, too.
Old 01-15-2011, 08:02 PM   #7
Suby2go
Member#: 270235
2008 Impreza WRX
You say you have fuel pressure, does that mean that your injectors are 100% spraying fuel? Cause you metioned that your plugs weren't wet, which makes me think that maybe your injectors are back or something to that affect, I would check them all just in case. Air, Fuel, and Ignition check them all.
Suby2go is offline   Reply With Quote
Old 01-15-2011, 08:31 PM   #8
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
dude....I'm pretty sure the issue was solved SIX YEARS AGO.
yarrgh is online now   Reply With Quote
Old 01-16-2011, 01:17 AM   #9
Suby2go
Member#: 270235
2008 Impreza WRX
hahaw I feel stupid, I am new to the forum. Now I know to check dates hahahahah
'02 WRX won't shift into 1-2 or 5th BlakeWRX06 Transmission (AT/MT) & Driveline 18 04-06-2008 05:44 AM
Help: WRX Won't Start! Crank Sensor? SyntaxPC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-24-2005 05:46 PM
Help please- WRX won't start Brewmaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-14-2002 09:48 PM
WRX won't start Dandand Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 08-06-2001 11:37 PM
