Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 01-19-2005, 01:29 PM   #1
Leadfoot77
Member#: 74268
2013 STi
Default bugeye headlights
Not sure if there is a more appropriate forum for this but whatever....
When I bought my WRX I found that the headlights seem to be VERY weak. Compared to other cars I've owned I cannot see nearly as well at night in this car. The combination of the headlights and the foglights seem better but still pretty subpar.
Is it just my car/headlights or is this common for a WRX?
Leadfoot77 is offline   Reply With Quote
Old 01-19-2005, 01:41 PM   #2
Akarui
Member#: 60195
World Rally Blue
hmm don't know but every Subaru I have ever seen has had HL so bright they almost looked like highbeams. I know in MY02WRX I get flashed all the time when I just have my normal lights on... Perhaps they need to be adjusted they could be aimed to low or too high?
Akarui is offline   Reply With Quote
Old 01-19-2005, 01:43 PM   #3
Akina
Member#: 51785
2003 WRX
You might look at brighter bulbs when you get them replaced.
Akina is offline   Reply With Quote
Old 01-19-2005, 01:49 PM   #4
Leadfoot77
Member#: 74268
2013 STi
i had the alignment checked and they were fine - maybe bulbs are the issue.
Old 01-19-2005, 02:09 PM   #5
MyRuRex
Member#: 21349
02 WRX Wagon
Low beams are OK but the highs are weak...IMO...
Better bulbs like Philips Hi-visibility or Vision plus or Osram Silverstars. All good bulbs w/o hi wattage. If you want hi wattage...you'll need those harnesses relay kits so you don't burn out the OEM wiring. See www.danielstern.com...
MyRuRex is offline   Reply With Quote
Old 01-19-2005, 02:10 PM   #6
wrxsubaruwrx
Member#: 60415
1973 Gran Torino
Green w rust coloration
Stock the wrx headlights blow....not much you can do about it . When I had mine I bought the silverstars but they didnt even make too much difference . I spent the $ and bought the jdm hid and just flattened the cutoff and now I can see !
wrxsubaruwrx is offline   Reply With Quote
Old 01-19-2005, 04:04 PM   #7
Howl
Member#: 57830
If you need more light on back roads at night you might want to consider adding driving lights. You can either replace your stock fogs (Hella 500's fit nicely), or keep the fogs and mount the driving lights separately in front of your upper grill (Hella FF50, FF75's or similar) or on a light bar (Hella 500's, 1000's or similar for the real rally look).
Howl is offline   Reply With Quote
Old 01-19-2005, 04:11 PM   #8
Tur1smoWRX
Member#: 35006
2003 WRX
HOT PINK
EDM STi HID's, dont think about it just do it!
Tur1smoWRX is offline   Reply With Quote
Old 01-19-2005, 04:42 PM   #9
garie
Member#: 26607
2002 wrx wagon
stock low bulbs in the bugeyes suck....i replaced mine with philips hi visibility bulbs from kmart for 18 bucks or so. They are supposed to put out 30% more light. They were somewhat better than stock. I recently replaced the bulbs in my jdm projectors with philips vision plus bulbs ordered from powerbulbs.com. These bulbs are supposed to put out 50% more light. The vision plus bulbs are pretty bright....big diff from the stock bulbs, check them out. WHiter brighter light. It took about a week to get the bulbs, since they were shipped from the UK.
-gary
garie is offline   Reply With Quote
Old 01-19-2005, 05:48 PM   #10
rbcsaver
Member#: 78039
02 WRX
WRX Blue
Make sure that your battery is OK and alternator charge across battery is around 14+ volts.
regards,
Steve
rbcsaver is offline   Reply With Quote
Old 01-19-2005, 09:50 PM   #11
ChungerSuby
Member#: 78091
Midnight Black Pearl
wait wrx's come with halogen lights?/??... are they the ones with the "magnifying glass" like in the new lexus'?
ChungerSuby is offline   Reply With Quote
Old 01-19-2005, 10:12 PM   #12
spitfirezip100
Member#: 64542
2006 S2000
in my opinion I think that the headlights on my MY02 are pretty weak compared to other cars I have driven ie. toyota camry, toyota corolla, even in combination with the fog lights. I would go with the EDM projectors and do a HID retrofit because no edm sti projectors come with hid's from the factory from what I have read the jdm ones did offer the HID option tho... if you need info on the edm HID retrofit install look up mattjk's headlight installation
oh yeah I also heard that if you do a grounding mod or kit install that it will help make your headlights brighter
spitfirezip100 is offline   Reply With Quote
Old 01-19-2005, 10:38 PM   #13
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
what? umm... no, halogen is a type of gas, the gas that the bulb is filled with. the bulb can be replaced...
i think you mean "projector" however it's NOT a 'magnifying glass" it's a lens... visit www.howstuffworks.com and look for lights
Handsdown is offline   Reply With Quote
Old 01-20-2005, 12:13 AM   #14
Dave6265
Member#: 51583
2014 JGC Overland
aka-Th3BlindMice
the forester is great with the HL's but the WRX is lacking a little bit,especially when i put the high beams on.. I may look into better bulbs one time for them
Dave6265 is offline   Reply With Quote
Old 01-20-2005, 07:47 AM   #15
Leadfoot77
Member#: 74268
2013 STi
well i'm on a bit of a tight budget so I think I'll start by trying the philips vision plus bulbs and see if those are adequate. What is a good place to get these at? The link provided above is to a uk site which would involve extra taxes etc... is it possible to get these in the US? I don't suppose they are readily available at parts stores?
Thanks for all the suggestions guys!!
Kevin
EDIT: I see uk appears to be where to get these - I'm confused as to what type I need though. I believe the manual says 9007(HB3) - do they make the vision plus in this type?
Old 01-20-2005, 06:24 PM   #16
speaker
Member#: 18453
MY02 WRX Sport Wagon
Relativity is everything. We bought an MY02 WRX & I liked the lights relative to the candles on my '95 Passat VR6. Then I got an Audi A6 2.7T w/ HID's & I don't drive my wife's WRX much anymore. I drove it last week & could not believe how bad the lights were.....
So, I installed Sylvania XtraVision 9007's last weekend at Pep Boys and was quite pleased with the improvement. Brighter, whiter light. While cleaning off the fogs, I noticed one was cracked so I ordered Hella 500 clear fogs & WRX brackets to replace them with. They're not on yet, but from what I've read here, they should be a nice improvement as well.
I'd start w/ the XV's first & go from there. I paid ~$20. They are ~1/2 of the SilverStar HID-oids. Total time to install was less than 20 minutes.
Good Luck!
speaker
speaker is offline   Reply With Quote
Old 01-21-2005, 05:00 PM   #17
FuzzyNips
Member#: 16686
2010 Mazda 3s GT 5dr
Black Mica
^Don't bother with the Sylvanias...since I believe you can't get the Osram's because you own a 2003 I'd go with the Philips' Hi-Visibility as previously mentioned, instead. The light won't be as white but it'll give better visibility which is far more important (at least to myself and any person with common sense).
FuzzyNips is offline   Reply With Quote
EDM Bugeye Headlight projectors into JDM Bugeye projectors? PhastEddie Interior & Exterior Modification 16 03-09-2007 01:46 PM
JDM/EDM bugeye headlight lenses = US headlight lenses? Jackie Interior & Exterior Modification 6 10-21-2005 01:55 AM
WTB bugeye headlight assembly thinkledge Private 'Wanted' Classifieds 1 04-18-2004 02:03 PM
Bugeye headlight painting questions JasonCSU Interior & Exterior Modification 55 01-20-2004 12:23 PM
Passenger side bugeye headlight FS $80 shipped supermarkus Private 'For Sale' Classifieds 0 09-17-2003 03:43 AM
