Old 01-19-2005, 03:04 PM   #1
wrxsc
Member#: 47289
Default Hesitation between 3-4k
Hey all just wanted to see what you guys think about some hesitation i've been getting between 3 and 4k, my theories are that I have a leak before the turbo or perhaps I should let the ecu control timing below 40% throttle b/t. 3-4k. Also what do you guys have your knock sensitivity at? I checked mine and its at 1. In addition I am not holding 18psi of boost but this could perhaps be due to the stock recirc. and txs hpbc i am using, I am switching to profec b shortly. Cheers.
Logs:
2594 -6.9 2.4 10 00 00 13.6 +36.2 8.7 ECU. +0.5 ECU. 2.2
2673 -5.7 2.5 15 00 00 13.7 +34.8 11.5 ECU. +0.5 ECU. 2.3
2727 -4.5 2.6 20 00 00 13.1 +33.9 13.1 ECU. +0.5 ECU. 2.4
2817 -2.8 2.7 24 00 00 13.3 +33.2 14.3 ECU. +0.5 ECU. 2.5
2888 -1.8 2.7 27 10 00 13.2 +33.0 17.1 +26.4 +1.5 ECU. 2.6
2973 -0.8 2.8 31 10 00 rich +32.4 19.4 +26.0 +1.9 300.00 2.7
3055 +0.2 2.9 32 10 00 rich +30.5 20.7 +26.0 +1.9 300.00 2.7
3192 +1.1 3.0 33 20 00 rich +29.7 21.2 +25.0 +0.1 300.00 2.7
3290 +1.9 3.0 32 20 00 rich +30.9 20.7 +25.0 -0.3 300.00 2.8
3280 -0.8 2.9 31 10 00 13.1 +31.2 21.2 +26.0 +1.9 300.00 2.8
3320 +0.2 3.0 33 10 00 rich +29.6 22.6 +26.0 +1.9 300.00 2.8
3370 +1.5 3.0 34 20 00 rich +30.6 21.7 +25.0 -0.3 300.00 2.8
3422 +2.7 3.1 34 20 00 rich +29.6 22.7 +25.0 -0.5 300.00 2.9
3468 +3.1 3.1 35 20 00 rich +27.8 22.9 +25.0 -0.6 300.00 2.9
3557 +3.9 3.2 35 30 00 rich +27.8 24.7 +23.0 -0.8 300.00 2.9
3603 +4.5 3.2 34 30 00 rich +27.4 26.2 +23.0 -1.1 300.00 3.0
3654 +4.7 3.3 34 30 00 rich +27.5 27.6 +23.0 -1.2 300.00 3.0
3687 +5.3 3.4 33 30 00 rich +26.8 30.6 +23.0 -1.5 300.00 3.0
3796 +5.7 3.4 30 40 00 rich +26.0 32.2 +18.2 -1.6 300.00 3.1
3844 +6.6 3.5 28 40 00 rich +25.3 32.8 +18.5 -2.0 ECU. 3.1
3907 +7.2 3.5 24 00 00 rich +26.0 32.4 ECU. +1.0 ECU. 3.1
3963 +7.2 3.1 11 00 00 rich +29.5 15.4 ECU. +1.0 ECU. 1.6
3889 +3.9 1.4 0 00 00 13.8 +32.8 5.9 ECU. +1.0 ECU. 1.3
wrxsc is offline   Reply With Quote
Old 01-19-2005, 05:09 PM   #2
jlee8196
Member#: 22211
There is a mod you can do by switch to GM solenoid for stock solenoid, that way you can use your Utec to closed loop boost. Do Search, it seems to hold boost (18psi+) well. I think the hesitation is do to utec swithching back to OEM , since you said under 40%tps. Do you have a WB02, I think running very rich cause hesitation too.
jlee8196 is offline   Reply With Quote
Old 01-20-2005, 12:39 AM   #3
wrxsc
Member#: 47289
thanks for the input but i am going to run a profec b electronic boost controller and am not using the stock solenoid currently. Also I think you are referring to the crossover point which is not causing the problem (i have already moved the point up and down the spectrum, messed with timing), also my afrs are in check and i am not running rich. Any more ideas anyone?
Old 01-20-2005, 03:19 PM   #4
TurbojonLS
Member#: 38772
2 Cars, No Bling
Your knock sensativity is at 1? Not 100? That's way, way, way too low. I'm using the stock UTEC parameter settings, but they're up around 100 somewhere.
Have you played w/ the maps at all? You're also looking like you're running too rich. I generally don't report "Rich" at such low boost levels.
What are your other mods?
TurbojonLS is offline   Reply With Quote
Old 01-20-2005, 03:32 PM   #5
hippy
Member#: 36528
2002 Impreza Wrx
1 is the default setting for knock detection threashold(not sensitivity), which is what I figure you mean. Some people set that to 2 because they either think that a 1 count means nothing, or that it doesn't do so much damage(I dunno). I have mine at 1..... If your knock detection sensitivity was at 1, you'd probably be seeing the utec report knock a lot more.
I don't think the boost controller has anything to do with the hesitation you're getting. What are your mods? What map are you using? Did the car hesitate in both of those logs? It doesn't look like there's hesitation there(to me), course it's not so easy to see in a log sometimes.
peace
Old 01-22-2005, 11:42 AM   #6
wrxsc
Member#: 47289
Actually I'm coming to think it was my electrical system. I tested my stock battery the other day and it was in bad shape so i replaced it with an optima and almost all of the hesitation is gone. I'm also gonna try a grounding kit to see if that yields any further positive results. Oh and yes thats my knock threshhold, I had a mind lapse and my sensitivity is in check with txs defaults.
Car hesitating to get past 3-4K RPM's pikon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-17-2007 01:42 PM
power lag between 3-4k rpm? GrandpreRS Engine Management & Tuning 0 01-09-2006 12:35 PM
hesitation at 3k-4k rpm SubyBean Normally Aspirated Powertrain 6 07-24-2004 12:38 PM
Tell me more about hesitation between 3-4k RPM? ThinkTank Normally Aspirated Powertrain 7 08-07-2001 05:33 PM
Cold Weather causing the 3-4k hesitation???? Keith Normally Aspirated Powertrain 17 10-24-2000 09:44 PM
