Old 01-19-2005, 03:47 PM   #1
Nutter
Member#: 7185
2015 FoST
Oxford White
Question where to get a 14mm hex key ?
I have an engine block heater that I want to install. You have to remove an engine plug first. You need a 14mm Hex Key for use with a socket set to remove this. Problem is I cant find one any where ! only metric size's are up to 10mm !
HELP
Nutter is offline   Reply With Quote
Old 01-19-2005, 03:53 PM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
One option is the 2nd item down on this page:
http://www.vehicle-wiring-products.c...2/tools-2.html
(assuming you are still in the UK). In general, what you want is a "hex driver".
Old 01-19-2005, 03:55 PM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
mbiker97 is offline   Reply With Quote
Old 01-19-2005, 04:09 PM   #4
Nutter
Member#: 7185
2015 FoST
Oxford White
Originally Posted by mbiker97
Thanks, yes I did see this but at $65 its a little spendy !
Old 01-19-2005, 04:10 PM   #5
Nutter
Member#: 7185
2015 FoST
Oxford White
Im in Chicago IL not the UK. But thanks
Old 01-19-2005, 05:37 PM   #6
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Woah you're right. I didn't even look at the prices, I just assumed it was cheap since it was Harbor Freight.
Doesn't your local Sears carry one?
Old 01-19-2005, 05:41 PM   #7
Nutter
Member#: 7185
2015 FoST
Oxford White
No I even had them look it up in the book and they dont carry that size ? !
Sucks !
Anyone else have a solution ?
Old 01-19-2005, 05:46 PM   #8
wawazat
Member#: 13793
2007 specB, 03 Ram
'92 SVX-5 speed
How about using a bolt with a 14mm head to engage the plug? Double nut the threaded portion to give you something for your wrench to hold on to.
Also, migght want to try a used tool store. Detroit has a couple in the 'burbs known as Re-tool.
Good luck,
Todd
wawazat is offline   Reply With Quote
Old 01-19-2005, 05:52 PM   #9
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Yeah the 14mm headed bolt will work and is pretty cheap. I got a 14mm 1/2" hex bit socket from mcmaster-carr. 5571A71 $10.71, you'd probably have it the next day. 3/8" only go up to 12mm.
Phil
Old 01-19-2005, 05:55 PM   #10
rogerd
Member#: 59934
2005 Legacy GT Wagon
Atlantic Blue
Snap On makes one - it's pricey. I made one. I raided my junk box and found a big old crank bolt (high tensile steel) and ground the head down to a 14mm hex using a bench grinder - you do need experience and/or a good eye to end up genuinely hexagonal - then ground a smaller hex on the other end to fit into a socket.
Cost $0, and I only wasted one bolt - it ended up a touch too small.
rogerd is offline   Reply With Quote
Old 01-19-2005, 08:24 PM   #11
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Can't beat diy.
Tim Sanderson is offline   Reply With Quote
Old 01-20-2005, 07:55 PM   #12
Nutter
Member#: 7185
2015 FoST
Oxford White
Good luck,
Todd
I tried this but I welded a nut on on end, however the bolt sheared right at the end of teh threaded part !
Phil, I will look at mcmaster-carr. Dont know why I didnt think to look there myself ! Thanks
Old 01-21-2005, 10:35 PM   #13
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Sorry about the UK ref; fortunately, Google handles stuff in the USA, too:
http://www.autozone.com/servlet/UiBr...EGRN%7C%7Etrue
It says the item is normal stock for their Crystal Lake store.
Old 01-22-2005, 10:49 AM   #14
avk
Member#: 17252
'06 WX8
59E
The 14mm bit is used for VW oil drain plugs, so it's easy to find wherever Euro maint. tools are sold.
Example.
avk is offline   Reply With Quote
Old 01-25-2005, 02:30 PM   #15
Nutter
Member#: 7185
2015 FoST
Oxford White
Now thats funny, I went to that store and they looked at me like I was from outer space !
I got one from McMastercarr, arrived in the mail in 2 days for about $10, 7" long.
John
Old 01-25-2005, 07:35 PM   #16
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
...they looked at me like I was from outer space !
You should have explained that the UK, though alien, is not quite all the way to outer space...
Old 02-08-2005, 02:12 AM   #17
punkrocksailor
Member#: 43376
Yep, I got the Snap-on one and never looked back.
(my Snap-on addiction is getting way out of hand)
punkrocksailor is offline   Reply With Quote
Old 02-08-2005, 10:48 AM   #18
attitude
Member#: 52043
04 sti
i got a 9/16" or 5/8" not sure which and ground it down
attitude is offline   Reply With Quote
Old 02-08-2005, 11:00 AM   #19
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Impreza GC8 local hardware store
My local hardware store carries hex keys in all sizes, including 14mm. I had no trouble locating it at all. I think I paid like $8 for excellent American-made 14mm hex key.
vvk is offline   Reply With Quote
Anyone know where to get Key for Spline Lugs ASAP? kerplunk Bay Area Impreza Club Forum -- BAIC 2 11-29-2004 02:42 PM
Where to get key cut for 'the club'? Rudypoo Vancouver Impreza Club Forum -- VIC 0 06-25-2004 02:42 AM
Where to get STi key cut near Boston? SiOrange New England Impreza Club Forum -- NESIC 12 04-22-2004 01:31 PM
where can i get 14mm Hex Key? ChAi North West Impreza Club Forum -- NWIC 18 11-10-2003 08:35 PM
Where to get key cut in Austin? gjhsu Texas Impreza Club Forum -- TXIC 5 01-30-2003 09:55 PM
