Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 01-19-2005, 05:11 PM   #1
Member#: 79878
13' Crosstrek
Default Problems installing air/fuel gauge on 92 legacy
Hey guys, i just wired power wire into the ignition so the gauge turns on when my ignition is on, as well as a ground wire.
Then i wired the third wire into my O2 sensor. There are 3 wires running into the sensor, i wired it into the black wire. I was told to tap into the signal sensor wire BETWEEN the PLUG and my ECU. I did that and it still doesn't register on the gauge. Did i use the wrong wire?
If anyone has any suggestions please let me know.thanx Ryan
ryno50485 is offline   Reply With Quote
Old 01-19-2005, 10:10 PM   #2
Member#: 4800
1990 Legacy & 97 OBS
Black is ground, white should be the signal wire.
You may want to check out www.bbs.legacycentral.org a lot more info for the first gen legacies
Legacy777 is offline   Reply With Quote
how to install an air fuel gauge on a 04 suby? iluvmyEJ20 Electrical & Lighting 3 07-18-2009 03:29 PM
air/fuel gauge install on 2002 rs ecu wire?! nineironputt Electrical & Lighting 2 11-12-2003 12:59 PM
Air Fuel Gauge Problem BrysImpreza Normally Aspirated Powertrain 2 01-07-2003 02:03 AM
Faulty fuel gauge on 93 Legacy Dealer Xing Legacy Forum 10 03-21-2002 12:37 PM
Installing an air/fuel gauge - quick questions BoomerRS Normally Aspirated Powertrain 9 11-30-2000 05:30 PM
