Old 01-19-2005, 08:10 PM   #1
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
Default i wouldn't be troubling you guys, but it's cold outside... what's your diagnosis?
okay, so i'm installing sidemarkers... they have the same plug on the back as the stock ones(they're authentic jdm subaru parts) so i cut the plug on the front sidemarkers in order to get the plug that will fit into them.
i cut the red with green stripe and the black wire, on the driver's side stock sidemarker...
it was dark so i had the lights on... i know, i know, stupid. but when i cut it, ALL the aux lights(at least in the front) went out.
so, did i blow a fuse? when i spliced the longer wires in, they still didn't work.
did i mix up the wires during splicing, or did i blow a fuse?
it's really cold outside and i don't want to go out there without knowing what to look for.
sorry, if i could go back in time i never would have chosen to do this... but seeing as i'm in the swamp, anyone want to help me out?
Handsdown is offline   Reply With Quote
Old 01-19-2005, 09:42 PM   #2
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
yup. blown fuse.
Old 01-20-2005, 10:28 AM   #3
don_xtc
Member#: 72378
3125 Impreza
Trying not to b0rk my car
Make sure you undo what ever wiring you did else you'll just blow another fuse
don_xtc is offline   Reply With Quote
Old 01-20-2005, 10:42 AM   #4
skyhawk
Member#: 36255
04 WRB WRX
Drive 2 Work,Work 2 Drive
You probably blew the fuse because you cut both wires at the same time and the tool you were using shorted out the + and the - wire. Just a guess. If you cut the + and - seperately then the tool had to ground on something while you were cutting the + wire. Not to be a smartass but don't cut any more wires with power on them. It makes life alot easier.
skyhawk is offline   Reply With Quote
Old 01-20-2005, 11:54 AM   #5
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
haha yeah it was cold and i wasn't thinking.
20 degrees and a sweatshirt really wasn't the best way to do this.
i fixed it now, it's all working fine.
Old 01-21-2005, 09:52 AM   #6
skyhawk
Member#: 36255
04 WRB WRX
Hands were probably shaking and teeth chattering being that cold and only wearing a sweatshirt too huh? LOL
MPG when it's cold outside? airwrench Factory 2.0L Turbo Powertrain 16 01-16-2009 12:09 PM
it's cold outside... alexlago Texas Impreza Club Forum -- TXIC 15 12-16-2008 02:34 PM
Stereo doesn't turn on when it's cold outside? fattysnax Car Audio, Video & Security 5 10-24-2008 12:13 PM
It's cold outside... welcome to raw fuel smell! rogue Mid Atlantic Impreza Club -- MAIC 31 01-19-2005 12:12 PM
It's cold outside and engine is ticking shippy1 Factory 2.0L Turbo Powertrain 6 10-06-2001 03:48 PM
Message Board Statistics All times are GMT -4. The time now is 07:57 PM.
