Old 01-19-2005, 10:17 PM   #1
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
Default I think i have a boost leak, i need help!!!
Ever since i moved to Iowa my car has been acting up. First, it died on me and i found out that my HKS BOV was leaking boost and making the car run really rich so that it died everytime i stepped on the gas.
Next, i put on another aftermarket BOV and my car would only boost to 10 psi, slowly, and hold there. So, i found my stock BOV and put that back on tonight. My car feels really slow, not responsive, and also surges during WOT. Boost climbs slowly to about 13psi. WIth my cobb map i should be boosting to about 16psi. Also, the entire time i am on the throttle, my car is making a loud wooooshing noise that seems to be coming from the drivers side. Also, my egts have been lower than normal and i used a 1/4 tank of gas in 40 miles.
I need help, how can I fix this?
Until about 3 days ago my car was running fine and boosting up to 16psi. All this started happening when my HKS BOV broke.
thanks for the help!
imprzya is offline   Reply With Quote
Old 01-19-2005, 10:22 PM   #2
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Stock TMIC?
Stock IC hoses?
Mods?
WRX_02_227 is offline   Reply With Quote
Old 01-19-2005, 10:24 PM   #3
supermarkus
Member#: 6971
2008 WRX STi
SSM
check your hoses and your BOV gasket.
supermarkus is offline   Reply With Quote
Old 01-19-2005, 10:25 PM   #4
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
stock tmic
samco IC hoses, just checked today
currently stock BOV
helix up/ helix dp (catless) cobb catback
Accessport running stage 2 91 octane base map, version 1.20
Old 01-19-2005, 10:27 PM   #5
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
we took my tmic off today and put the stock BOV back on. All the hoses around the intercooler and the stock BOV is fine.
the blowing sound seems to be coming from the drivers side
poor rex
Old 01-19-2005, 10:38 PM   #6
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
You took of the TMIC to put the stock BOV on? Are you sure sure sure sure that all the clamps are tight on the samcos including the BOV dump hose? Throttle body clamps are tight?
Old 01-20-2005, 12:40 AM   #7
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
Yes, we just put on the BOV dump hose today and when we put the IC back on we made sure all the hoses were on tight. Even after all of this boost is still leaking out.
Cliff notes:
HKS BOV leaked, car ran rich and died when clutch was pushed in
Installed other aftermarket BOV, boost still leaked, car would only reach 10psi, but was running leaner and didnt die
Took off top mount, installed samco bov dump hose, checked all hoses, put stock top mount back on and installed stock BOV, car now boosts to 13psi and you can hear the boost whiz out when you step on it.
Old 01-20-2005, 01:08 AM   #8
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Maybe an uppipe leak?
You would see a loss of boost with an uppipe leak.
Old 01-20-2005, 10:48 AM   #9
JenisonWRX
Member#: 6049
02 WRX & 99 RS
it would also be loud as hell and not a constant 'pfffffft' sound when she gets on it. I talked with her last night about this issue.
Thats the only thing that steered me away from this problem. However, I told her to check the manifold anyway.
I suspect there is a crack in a hose somewhere or leak that is only exposing itself under boost.
JenisonWRX is offline   Reply With Quote
Old 01-20-2005, 11:20 AM   #10
JLOWRX
Member#: 62962
04, STi
02 sti wagon, 06 e90bmw
I having the same problem and i was told that my turbo might be going out so time to upgrade.
JLOWRX is offline   Reply With Quote
Old 01-20-2005, 11:38 AM   #11
Jduke
Member#: 29699
2005 Legacy GT Wagon
Red
did you replace the gasket for the IC/BOV? That would cause alot of problems...
Jduke is offline   Reply With Quote
Old 01-20-2005, 01:36 PM   #12
chefmansakai
Member#: 45949
04 WRX
i dont think i have a boost leak but i seriously think there is something wrong with my HKS SSQV bov. It just sounds like its not releasing any air.
chefmansakai is offline   Reply With Quote
Old 01-20-2005, 01:37 PM   #13
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
this weekend i am going to take off my IC again and check all the lines. the BOV gasket looked fine when put the stock BOV back on
Old 01-20-2005, 02:15 PM   #14
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
Not true....I have a small uppipe leak right now...and it's a constant pfffft when I'm boosting (I've lost a slight amount of boost because of this). You might want to check your uppipe gasket(s)...my gasket at the header side was cracked and a new one fixed it.
YM'sL +$0.02
YourMother'sLover is offline   Reply With Quote
No Boost 04 WRX...need help. tried as much as i can think of squigy123 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 08-16-2009 10:12 PM
cel, system too lean after boost leak fixed, need help csimp3 Newbies & FAQs 8 11-14-2008 09:02 PM
Boost leak test....need help Tronner Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-15-2007 09:52 AM
I think that I have a boost leak JLOWRX Texas Impreza Club Forum -- TXIC 4 01-20-2005 11:05 PM
So i think i have a boost leak, how do i test this? jefersun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-20-2004 09:58 PM
