Old 01-19-2005, 11:17 PM   #1
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Default Link Plus: Question on RPM pin output
I am trying to wire in my RPM logger function on my new TechEdge wideband O2, and I can not find the RPM sensor output pin on the Link Plus wiring harness.
At this point, my best guess is the TRIG 2 (blue) or the TRIG 1 (white) wire. It says that the TRIG 2 wire has a cam/crank sensor function in the manual, but would this be the correct wire to tap for the RPM count? Also, the manual says that the TRIG 2 wire should not have any interference, as this is a very important wire because it controls ignition timing, injectors, fuel pump, etc..
Would the Tacho (white/green) output be capable of driving a logger function for a wideband software application?
Any help is appreciated, as I need to get this thing running soon (have a tune comning up).
Graham
Graham is offline   Reply With Quote
Old 01-20-2005, 12:13 PM   #2
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
need to get this working....
Old 01-20-2005, 05:16 PM   #3
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
I would not use the crank or cam angle sensors for a tach signal. I don't know if the techedge can use the variable reluctance sensors that we use to figure out the rpm. Your best bet would be to use the tachometer output from the link (pin B8) to drive the tachometer input on the techedge.
-Chav
Chav is offline   Reply With Quote
Old 01-20-2005, 07:06 PM   #4
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Thanks for the information Chav. Apparently, though, the RPM jumper block on the component side of the board inside the TechEdge brain has two pins that need to be jumpered to accept the +12v that the Tacho (as Link calls it) outputs. Otherwise, you have to find a 0-5v source from which to draw your RPM signal. I do not think that there are any 0-5v sources that output an RPM signal on the Link wiring harness.
I am in the process of trying to contact Peter from TechEdge in Austraulia see if he has any alternatives. Otherwise, any ideas on where I can buy jumper (or shunts) so the jumper block can accept a +12v current?
Thanks
Graham
Old 01-21-2005, 12:06 AM   #5
Chav
Member#: 3269
RSTi
You could just use a voltage divider to bring the voltage down to the 0-5v range.
Here is a link to an example.
http://people.clarkson.edu/~svoboda/...derDesign.html
If you need help with the circuit diagram I can help.
-Chav
Old 01-29-2005, 12:52 AM   #6
erice1984
Member#: 11778
1980 VWRabbit Diesel
w/AAZ Swap
on a stock my00 2.5rs the pin out is on connector b134 terminal number 30 it is called engine speed that would be B8 on the link plus, and it says wire color for that is white-green
erice1984 is offline   Reply With Quote
Pic request for RPM pin site on 2004 USDM STi ECU PA04STI Commercial ECU Reflashes 6 05-22-2007 10:43 PM
Need Pic of RPM pin site on 2004 USDM STi ECU PA04STI Electrical & Lighting 1 05-20-2007 10:40 PM
rpm pin on comp. chris d Tri-State Area Forum 1 10-11-2002 07:40 AM
rpm pin # on wrx comp chris d Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-11-2002 02:30 AM
question on RPMS when not in gear moogooob Transmission (AT/MT) & Driveline 5 09-23-2002 05:20 PM
