Old 01-20-2005, 01:25 AM   #1
mikeG8U
Member#: 55299
02 WRX
Default ecu timing
I have been out doing some logs on my new setup. I am picking up knock from the utec right at 5000rpms. The stock ecu timing is still gradually increasing where the utec is picking this up. Is this a false knock? Are the knock thresholds to sensitive in that range ( set to 93 in 4-5K range) ? The ecu will detect knock under 5500rpms, correct? I am also running a ej257 with cp pistons. Could there be some extra noise or vibration going on at this point??
TIA
Mike
mikeG8U is offline   Reply With Quote
2005 ej25 on 1995 ej18 ECU, timing off? jester409 Built Motor Discussion 11 05-10-2009 05:29 PM
ECU timing, UTEC everything else...?? aznatama UTEC 5 01-23-2007 08:23 AM
OK..questions about JDM ECU timing if anyone knows?? 2002WRXSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-13-2004 06:24 PM
So I've been experimenting Utec vs ECU timing control... Si2WRX Engine Management & Tuning 6 08-25-2004 02:26 PM
Stock WRX and ECU timing thoughts? SnortWagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-10-2002 04:39 PM
