Old 01-20-2005, 12:28 AM   #1
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
Default Fuel pump wiring questions
I want to install a fuel pump cut off switch onto my car. The problem is i dont know were the wire runs and what color it is. Does anyone know which wire is it and were i can locate it. I know i can locate the pump and just follow the wire but if someone know off the top of their heads it would be easier.
~Leor
WRC1 is offline   Reply With Quote
Old 01-20-2005, 06:17 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Get the factory manual for your car here-
http://techinfo.subaru.com/html/index.jsp
For $20 you can get a 72-hour subscription which will allow you to download as much of the manual as you want/need. Once you have the wiring diagrams you'll have all the info you need to answer questions such as this.
Also do not connect a switch directly to the wiring that goes to the pump itself. Instead use the coil wires to the fuel pump relay, that way you'll be switching only a small control current rather than the full operating current of the pump, and the chance for failure of the switch will be much less.
Fuel pump wiring LIFEFORM Subaru Conversions 2 10-10-2005 10:53 PM
Forester VS Impreza fuel pump wiring? pitcrew Subaru Conversions 0 09-27-2004 01:17 PM
Question on fuel pump wiring. Please help! RicerJim Mid Atlantic Impreza Club -- MAIC 12 04-12-2004 11:58 AM
Color of Fuel Pump wire WReX'N Car Audio, Video & Security 7 09-23-2003 06:02 PM
Fuel pump wire location for GC8 for fuel cutoff switch wastgate Car Audio, Video & Security 2 06-26-2003 03:50 AM
