Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 01-20-2005, 06:08 AM   #1
mw1029h
Member#: 51726
04 STi "Cloaked"
Blk,"member of team blew"
Unhappy Radiator leak?
Ok, so I had some work done on my car afterwards I smelled antifreeze. I thought that it was just some spillage and that maybe the case, but when I turned on the heater the smell was so strong that It made my eyes water . I took the car back and no leak was found. I took the car to the dealer "Pressure test" and not leak was found. I don't drive the car much but I can still smell the antifreeze not as strong but the smell is still there . If antifreeze had spilled in the engine compartment can it be trapped somewhere if so where ? thanks
mw1029h is offline   Reply With Quote
Old 01-20-2005, 09:22 AM   #2
vile
Member#: 32371
'02 t-rex wagon
platinum
the radiator leakage issue was seen mostly in the '02 wrx, which doesn't seem to apply to you. and if you do have a leak, it's usually at the plastic end tank. so check the sides of your radiator
what exactly did you have done? and yes, there are gullies and nooks which will allow for a nice little pool to build in your engine bay.
check to see if you have any white residue on any of the hoses, esp the radiator hoses.
else, take it to the dealership.
vile is offline   Reply With Quote
Old 01-20-2005, 06:41 PM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Whoever did 'the work' likely spilled coolant on the passengers side head and on top of the block, and that has pooled and is sloshing around getting on the exhaust and heating up and stinking and all that..... rinse off the top of the engine well, weather permitting, and see if that helps
Old 01-21-2005, 01:32 AM   #4
mw1029h
Member#: 51726
04 STi "Cloaked"
OK thanks I'll try that
Old 01-21-2005, 01:33 AM   #5
mw1029h
Member#: 51726
04 STi "Cloaked"
Done that, the dealership.
Old 01-24-2005, 02:32 PM   #6
mw1029h
Member#: 51726
04 STi "Cloaked"
Update problem solved,washed and rinsed the engine and compartment zoomed up the FWY smell is gone.
Old 01-27-2005, 06:10 PM   #7
Sonic Yellow 2K3 WRX
Member#: 33236
Mine looks like "sweat" coming from the top of my radiator. Does anyone have a link to a pic or pdf of the tsb? How serious is this in the short term?
Sonic Yellow 2K3 WRX is offline   Reply With Quote
Old 01-27-2005, 10:36 PM   #8
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Not at all unless you let the coolant get low and it overheats.
possible oil leak and radiator leak MachinesWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-18-2006 07:23 PM
Radiator leak WRXterminate Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-24-2003 12:11 AM
Radiator Leak MissWRX Tri-State Area Forum 5 01-24-2003 06:33 PM
WRX Radiator Leaking WRX4FUN South East Region Forum 25 12-31-2002 04:30 PM
First it's radiator leaking, then clutch master cylinder resorvoir leaking, and then. davidm_sh Warranty Issues & SOA Problems 1 03-24-2002 01:43 AM
