Old 01-20-2005, 08:50 AM   #1
Tattoo Collector
Member#: 19364
1998 Impreza RS
Black Mica Pearl
Default Can I reuse block bolts/head bolts
I am rebuilding my motor and I was wondering if I could reuse the bolts that hold my block together and my head bolts, or are they torque to yield? I am assuming that the head bolts will have to be reused but I am not really sure on the bolts for the block.
Tattoo Collector is offline   Reply With Quote
Old 01-20-2005, 09:02 AM   #2
quantum
Member#: 73416
05 CTS-v
Stealth Grey
Unless things are really different between domestic and foregin parts you should be able the reuse them. I've used the same bolts on a chevy 350 5 or 6 times. Though, if you need added strength (holding the head on, or the block together for a nasty engine) a set of really nice bolts is never a bad idea.
quantum is offline   Reply With Quote
Old 01-20-2005, 09:38 AM   #3
Boost-Free Subee
Member#: 61052
1999 2.5 RS
although it is recommended to replace them every time you remove them (as the threads will stretch slightly after they are torqued) most mechanics at dealerships don't even do it. if you are building an uber-nasty motor though, ARP head studs are the way to go. (around $250 a set)
Boost-Free Subee is offline   Reply With Quote
Old 01-20-2005, 09:49 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I haven't replaced them on the last two motors I have put together, with no problems to date. And there is a very specific torque sequence and series. I am just pulling this from memory, so be sure to look it up, but it is something like
1-6 (you will need a manual to see which bolt is which #) to 21lb
1-6 to 52lbs
back them off in order 180 degrees
back them off in order another 180 degress
tighten 1 and 2 to 27lb
tighten 3-6 to 22lb
tighten them all in sequence 90 degrees.
Tighten them all in sequence again 90 degrees.
Like I said, don't do it off my memory, which is poor, but you get the idea. If you don't do it this way you can warp your heads...
Old 01-20-2005, 10:35 AM   #5
Boost-Free Subee
Member#: 61052
1999 2.5 RS
1-6 to 52lbs
tighten 3-6 to 22lb
that's pretty much what TWE sent for directions for my heads... sounds right to me, but, like you said, i don't have the page in front of me, so i'm not positive.
Old 01-20-2005, 04:42 PM   #6
Tattoo Collector
Member#: 19364
1998 Impreza RS
Black Mica Pearl
Default Thanks.
I have a subaru factory service manual, so I have all the torque specs. I was just wondering if you could use the headbolts or not.
As far as the guy with the chevy stuff, some bolts can be reused and some cannot. I just didn't know as to this specific application.
I am building a fairly serious motor, but as far as the head bolts go, I don't think I need the ARP headstuds. Not yet at least. The next motor, they will be a must have.
Old 01-20-2005, 05:52 PM   #7
Storz
Member#: 77586
91 Miata
Red
I reused all the head bolts etc when I did my 4A-GE last year from the MR2 and I put 6k hard miles on it before I sold it with now problems, just make sure you torque them in the right order a little bit at a time
Storz is offline   Reply With Quote
Old 01-20-2005, 07:56 PM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Yes you can re-use them.
Tim Sanderson is offline   Reply With Quote
Old 01-20-2005, 09:52 PM   #9
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
You can but you are not suppose to. I am a mechanic and reusing headbolts is a no-no
Russell Rogers is online now   Reply With Quote
Old 01-20-2005, 10:12 PM   #10
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Ding Ding, torque to yeild not suppose to reuse them. Why do you think you torque them in sequence and in incriments. stretching etc.
Every Head Set I have ever gotten has included new head bolts.
Jay
Old 01-20-2005, 10:44 PM   #11
techworkseng
Member#: 21604
Default Head Bolt Replacement
Hey, I just happend to be searching and thought I'd chime in...
This is taken from our Cylinder Head Package installation instructions;
Caution: Cylinder Head Bolts are streched to yeild requiring that a new set of bolts is used each time the cylinder head is reinstalled.
Installation notes:
1) Install new cylinder head gasket and cylinder head onto cylinder block
2) Tighten cylinder head bolts following the numerical order that follows.
a) Tighten all bolts to 29 N∙m (3.0 Kg-m, 22 ft-lbs) in numerical sequence
b) Tighten all bolts to 69 N∙m (7.0 Kg-m, 51 ft-lbs) in numerical sequence
c) Back off all bolts by 180
d) Back off all bolts by a further 180
e) Tighten bolts 1 and 2 to 34 N∙m (3.5 Kg-m, 25 ft-lbs)
f) Tighten bolts 3 - 6 to 15 N∙m (1.5 Kg-m, 11 ft-lbs)
g) Tighten all bolts by 80 - 90 in numerical sequence
h) Further tighten all bolts by 80 - 90 in numerical sequence
Sorry I can't post the picture with the numerical sequence to illustrate this better. If you'd like to PM me I can forward you the file. We are working on a Tech Page for the website that will include all our installation instructions.
Thanks,
Keith
techworkseng is offline   Reply With Quote
Old 01-20-2005, 10:58 PM   #12
Tattoo Collector
Member#: 19364
1998 Impreza RS
Black Mica Pearl
Hi Keith. Thanks for the info. I just called there tonight and spoke to someone (i forgot his name; i'm terrible with names) and got some very good info. You guys are the best out there. I wish you were closer to me! Anyway, thanks again for the help and I'll get some dyno numbers for you on that header as soon as the car is running.
Old 01-21-2005, 03:58 AM   #13
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Just my two cents worth, but when you back the bolts off the full 360 Deg, you will have a bit of space to squirt some more lube under the washers/bolt heads-eliminated alot of 'bolt-grab' for me....
sixpack subaru is offline   Reply With Quote
Old 01-21-2005, 04:04 AM   #14
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
I have changed about 50 2.5 sohc head gaskets at a dealer and reused every single head bolt without one failure. If bolt replacement was required then subaru wouldn't pay the claims due to the bolts not being charged out on the repair order.
00Maddog is offline   Reply With Quote
Old 01-21-2005, 04:10 AM   #15
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
I talked to ron at axis today because my arp head studs are a bit short for my sohc heads he told me I would be fine re using my headbolts as long as i use the proper tightening sequence etc.
speed_freak27 is offline   Reply With Quote
Old 01-21-2005, 07:56 AM   #16
sixpack subaru
Member#: 64974
Subaru Stars
Hey Bud,
IF it was the case....
If you read the 'Shop Manual carefully it will give you specs to check the bolts against, measure, tension and measure....time consuming, but cheaper than replacing bolts!!!!
Cheers,
(btw:did you know that the average load on any one head bolt/stud under normal operating conditions is between 1-1.5 tonnes, and when an engine detonates it can rise as high as 7 tonnes!! PER BOLT!! )
Sixpack Subaru
Old 01-21-2005, 08:54 AM   #17
quantum
Member#: 73416
05 CTS-v
Stealth Grey
Well, I would follow the directions if you have explecet ones that say change the head bolts. Maybe chevy's are different, or it could be that since I started with a nice set of arp bolts I got away with it. Anyway, like I said in my first post "A nice set of new bolts is never a bad idea."
Old 01-21-2005, 10:20 AM   #18
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
I believe 8complex has reused his like 6+ times If I remember reading correctly.
Old 01-21-2005, 06:54 PM   #19
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
I don't care who has or does reuse them. Never ever reuse headbolts. I know for a fact that Subaru does say to put new bolts in when removing head.
Old 01-22-2005, 02:35 AM   #20
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
As the "by-the-book" technician, you should replace headbolts. Especially those applied to TTY. Actual mechanics don't and usually reuse them just once or twice. Some TTY bolts such as those for mid to late 90s Volvos had their factory recommendations set to no more than 5 times of reuse.
Reuse or using new, it's a divided opinion among mechanics and technicians. I know plenty who've reused headbolts with no problems and those individuals have been Subaru mechanics/technicians for longer than I existed. Many here on NASIOC.
But, if one of them bolts snaps off as you torque it down, expect to have a very p00py day.
-paK +1
Pakin is offline   Reply With Quote
reusing head bolts hypoxvi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-01-2009 07:22 AM
Can I reuse my flywheel bolts? Jpizzzle Transmission (AT/MT) & Driveline 6 11-09-2007 10:18 PM
JDM wrx block and head bolt on to US wrx intake exhaust? SoBaLo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 06-18-2005 10:02 PM
Can I Reuse the Washers on the Banjo bolt Silverandscared Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 09-01-2004 10:31 AM
Can I reuse my block? scoobyimprza Normally Aspirated with bolt-on Forced Induction Powertrain 2 02-22-2004 06:47 PM
