Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 01-20-2005, 08:30 AM   #1
SpaceGhost
Member#: 69913
2011 STI Limited
Dark Grey Metallic
Default Oil spray when changing oil.
I have an 05 STI and I have noticed that when I drain the oil it sprays out like a "fire Hydrant" unlike my 02 WRX it came out in a nice even stream. Does anyone else have this problem? It makes quite a mess whe I change my oil. Should I have the dealer look at it or is this normal?
SpaceGhost is offline   Reply With Quote
Old 01-20-2005, 09:01 AM   #2
Uncle Scotty
Visiting NASIOC Timeout
Member#: 16200
OK buy Nates beans
westcoastroasting.com
You may have a PCV issue.....it also helps to loosen the fill cap(or pull the dipstick) to vent any crankcase pressure that may be present.
Uncle Scotty is online now   Reply With Quote
Old 01-20-2005, 09:30 AM   #3
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
He has no PCV issue. This is how mine is too. It is mostly due to the design of the STi oil pan (so different compared to other USDM subarus). This causes the oil to swirl as it proceeds toward the hole. Also, the hole in the pan is not just a hole into the pan. Look up into the hole and you will see a very small protective cage that extends up into the hole the depth of the plug. These two factors cause hot oil to spin and spew out like crazy when you drain the oil. It is not a problem.
t
WolfPlayer is offline   Reply With Quote
Old 01-20-2005, 09:40 AM   #4
SpaceGhost
Member#: 69913
2011 STI Limited
Dark Grey Metallic
t
Thanks I just purchased a fumotovalve which I saw in another post while I was searching. www.fumotovalve.com Maybe this will help me.
Old 01-20-2005, 11:00 AM   #5
WolfPlayer
Member#: 65054
2005 STI (CGM)
It will help dramatically. I have one on my car now too.
t
Prevent oil spillage when removing oil filter? broosewee Service & Maintenance 17 05-28-2008 10:38 AM
crush Washer when changing oil snapperswrx Service & Maintenance 16 05-12-2007 02:08 AM
Is it safe to go to any oil shop to change oil? Fleek04 Vancouver Impreza Club Forum -- VIC 23 02-13-2006 01:25 PM
Does anyone use a oil extractor (Tempo Oil boy) when doing a oil change SlimSE Service & Maintenance 8 12-12-2005 07:10 AM
new crsuh washer needed when changing oil? and whats a good oil filter? jmott Texas Impreza Club Forum -- TXIC 16 08-07-2002 06:33 PM
