Old 01-20-2005, 12:08 PM   #1
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default New Axle Shaft Breakage/Damage TSB
SOA recently issued a new TSB and its description is at http://techinfo.subaru.com/html/disp...p?doc_id=73234. I hadn't realized that people were breaking their axle shafts often enough to warrant a TSB about the problem.
Jon [in CT] is offline   Reply With Quote
Old 01-20-2005, 01:31 PM   #2
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
I agree with you Jon. Nice find BTW....you and your damn searching skillz!
Old 01-20-2005, 04:28 PM   #3
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I think that has to do with the STI more than anything else. If the DCCD stays open or you are in manual mode and set it that way 2/3 of the torque goes to the rear wheels. If guys launch by just dumping the clutch at 6000rpm, you can get axle hop in the rear which snaps axles, usually at the outer CV. I've read 5-6 cases of this on the board here alone. It's a lot better than breaking the rear diff or transmission. The new axles are expensive, although it only takes about 10 minutes to swap them, I've heard of them getting covered under warranty. I can't see how under any normal driving you'd break them.
Old 01-20-2005, 04:53 PM   #4
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
I've snapped 2 axles... it's annoying.
no-coast-punk is offline   Reply With Quote
Old 02-10-2005, 08:48 AM   #5
mclendonmdw
Member#: 81233
Exclamation Broken Rear Axles
I experienced the disappointment of breaking my rear axles first hand last week. My factory STI has been in the shop since. I have gone back and forth with the dealer. I was not launching at 6000 RPM as the TSB describes the root of the problem. I hit 2nd gear at like 4500 RPM and that was enough I guess. So donít drive like Solberg because the rear end in the STI are not designed to handle the 300ft-lb of torque the engine and transmission are touted deliver. They did agree to pay for 1/2 of the more than $1200 service fee.
mclendonmdw is offline   Reply With Quote
Old 09-21-2006, 09:42 PM   #6
tailout
Member#: 6152
2005 STi
Mine was replaced completely under warranty!!! THANX SOA!!!
2005 Subaru STi
Turbo Mods-
FP 20G turbo
Injen phantom FMIC
Power-enterprise 850cc injectors
FORGE UNOS boost controller
FORGE recirculation BOV
Carbon fiber front air duct
GReddy radiator shroud
Invidia bell mouth DP
Vibrant Cat-Back N1 style Exhaust
Perrin BIG MAF
Perrin turbo inlet tube
Exterior-
Work EMOTIONS bronze 18x8.5
Charge Speed CF front lip
Suspension-
CUSCO Zero 2R coilovers
Hotchkis competition sway bars
Hotchkis rear lateral links
Hotchkis Rear Camber Links
Hotchkis Swaybar Endlinks
Interior-
Valentine V1 hardwire ready
Defi control unit
Defi boost gauge
tailout is offline   Reply With Quote
FS: rear half-shaft, axle shaft STi garagedefeat Drivetrain 5 05-29-2009 11:50 AM
10 second Subaru - shaft breakages sko081 Built Motor Discussion 3 09-04-2007 05:49 PM
USDM 6 spd swap, Axle shaft?'s AK'S REX Transmission (AT/MT) & Driveline 6 08-03-2005 11:09 AM
Axl Shaft & Crank Seal Leaking BLuExTaCiE Mid West Subaru Owners Club Forum -- MWSOC 9 10-03-2004 11:52 PM
Replacement STI Axle Shafts? scottinal Transmission (AT/MT) & Driveline 20 10-30-2003 05:17 PM
