#1 |
Member#: 59226
Vehicle:2005 Sti WRB |
Hey guys I need a new power steering belt for my legacy. Should I just go to the dealer and tell them to put a new belt or should I buy the belt and do it myself? I never done it before so I don't know if the installation's going to be easy or not. Any advice would be appreciated.
masube
#2 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper Wagon |
Get it from a local parts place.
It should take only ~10-15 minutes to do. Maybe get both the AC and PS/ALT belts and do at the same time? |
#3 |
Member#: 53410
SWIC
Vehicle:BE-> GD->GR->SG->BL WAawd.org |
it should be relatively easy if you've got some idea of what you're doing...the only 'difficult' part would be tension'ing the belts correctly.
I'd pick up a haynes manual or something and see how they tell you to do it. I think theres some type of special tension tool to measure how tight the belt is in order to compare to OEM spec. |
| Thread Tools | |
| Display Modes | |
| Need help with power steering pump banjo bolt assembly | hybrids220 | Factory 2.0L Turbo Powertrain | 1 | 05-20-2010 09:38 PM |
| Need help with power steering pump | zeroek | Factory 2.0L Turbo Powertrain | 0 | 09-27-2008 05:56 PM |
| Tension on power steering belt | PHustle | Newbies & FAQs | 0 | 05-30-2007 09:12 AM |
| Need Help w/power steering pulley removal | cdigerlando | Factory 2.0L Turbo Powertrain | 11 | 03-21-2007 11:23 AM |
| need help on power steering belt. | masube | Legacy Forum | 3 | 11-28-2004 12:21 AM |
