Old 01-20-2005, 05:05 PM   #1
crayons
Member#: 79939
Default JDM Spec C engine queries
Hi all!!!
Am hoping for some advice from anyone here who can help...
has anyone dropped a jdm sti spec c engine in their subaru b4?
was told by several workshops that the spec c engine basically uses the same engine block as a standard jdm sti...however, the only difference between the jdm spec c and jdm sti is in the design of the spec c's heads as well as its higher lift cams.
does anyone know more about this?
any help is greatly appreciated.
thanks!
crayons is offline   Reply With Quote
Old 01-20-2005, 10:07 PM   #2
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
You were told right... Different head/cams for the spec C/Type RA cars, for the most part.
Old 01-21-2005, 01:17 AM   #3
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Who ever told you this knew what they were talking about. Like everyone else has said before Legos. That engine can go into any Subaru that came with an EJ series engine. If the car is currently not swapped you'll need the entire harness and ECM to run the engine to it's full capacity. If it's going into an '02 or later WRX you can get by with the ECM and a little bit of wiring that is needed to run the AVCS.
Z
Zephyr is offline   Reply With Quote
Old 01-21-2005, 05:12 PM   #4
crayons
Member#: 79939
thanks for the clarification guys...that has really helped alot!!!
JDM Spec C engine N8WRX Engine/Power/Exhaust 3 11-25-2009 09:30 AM
JDM Spec C engine N8WRX NESIC Private Classifieds 4 11-25-2009 09:30 AM
JDM V8 Spec C engine vs JDM V8 STI DScamp Subaru Conversions 2 04-08-2007 01:46 AM
JDM Spec C engine queries crayons Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-24-2005 10:02 PM
