Old 01-20-2005, 09:15 PM   #1
scoobaru_wagon
Member#: 79950
Default how much boost for stock wrx turbo in wrx
so how much till it runs out of effiiency anybody have a compressor map of it. what is it a mitsu td 04 if so which one they have like 3 of em
scoobaru_wagon is offline   Reply With Quote
Old 01-20-2005, 10:20 PM   #2
hotrod
Member#: 14141
2002 Impreza WRX
The stock turbo is generally most effecient up to about 16 - 16.5 psi. Above that you can only use the higher boost in the midrange rpms as the air flow is still within the capacity of the turbo. No matter what you set the turbo to, at 7000 rpm you will see boost drop down near 14 psi or so because the turbo simply cannot provide enough air to maintain a higher boost pressure.
At higher rpms and boost level settings above 16 psi you need to be sure you have adequate fuel octane to prevent detonation.
If you had asked this question a few days ago I would have said yes we have a compressor map, but the map that everyone was using was for the 13G compressor which we now know is not the correct compressor for the stock WRX turbo. It has a 13T compressor which flows slightly more than the 13G, but unfortunately, no one has found a 13T compressor map yet.
Based on our experience over the last few years, the 13G compressor map is probably good enough for most applications but the 13T probably flows slightly more at max flow, possibly 385 CFM vs the 360 CFM rating of the 13G.
Larry
hotrod is offline   Reply With Quote
Old 01-26-2005, 07:34 PM   #3
scoobaru_wagon
Member#: 79950
[quote=hotrod] thank you sir i appreciate it so if i run 15.5 im straight. thanks alot i didnt want to be turning my turbo into a hair dryer at 15.5psi thanks
Old 01-27-2005, 05:06 AM   #4
Roffa
Member#: 30717
2002 Impreza WRX
I run 21 psi boost on my edm wrx. It's alittle high but no problems yet.. Have been boosting this for the last 30k miles @ norwegian 98 octane fuel.
Only engine mods are catless exhaust, kn filter and mbc But just because I have no problemes doen not mean I recomend this high boost..
Roffa is offline   Reply With Quote
Old 01-27-2005, 07:31 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i too run higher boost on the oem turbo. 19psi in the midrange. it tapers itself to ~15psi at redline. mods are on www page. logs show more maf voltage with higher boost in midrange.
hth
ken
Old 01-27-2005, 09:02 AM   #6
Bayley
Member#: 49763
2004 WRX
Jetzt mit 25% mehr Motor!
I'm curious as to how people are getting 15 psi at 7000 rpm on a stock turbo. With an electronic boost controller trying to maintain 16.5 psi, the best I can do is usually about 11 psi by 7000 rpm. Even by 5000 rpm, the boost is already starting to drop off. Please note, boost is controlled solely by an electronic controller. The ECU has no control over the boost levels any more.
Third gear pull at WOT:
Bayley is offline   Reply With Quote
Old 01-27-2005, 10:36 AM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
more info here http://forums.nasioc.com/forums/showthread.php?t=657897
bayley: mod list?
ken
Old 01-27-2005, 10:54 AM   #8
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
Efficiently, the stock TD04 boost I would say is 16psi. Anymore than that and youshould consider getting a bigger turbo.
darksands is offline   Reply With Quote
Old 01-28-2005, 01:05 AM   #9
turbocolin
Member#: 43539
95L 97L 03hedgehog
02 wag 180mph monster
what is stock boost 14.5
turbocolin is offline   Reply With Quote
Old 01-28-2005, 01:05 AM   #10
turbocolin
Member#: 43539
95L 97L 03hedgehog
or 1 bar i know they are the same thing
Old 01-28-2005, 01:27 AM   #11
TJRCS
Member#: 59199
2008 STI
stock boost is 13.5 PSI
TJRCS is offline   Reply With Quote
Old 01-28-2005, 02:41 AM   #12
turbocolin
Member#: 43539
95L 97L 03hedgehog
where is the stock bc on the wrx
Old 01-28-2005, 05:10 AM   #13
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
Behind the center console... The ECU.
Old 01-28-2005, 05:51 AM   #14
NWWagon
Member#: 66769
05 Focus "ST"
'80 Honda CM400T
You can get the stock turbo to maintain boost at higher RPMs better by having a "Clip" performed on the hot side, but you'll loose some responsiveness and bottom end.
EDIT: Pardon me, Clipping the turbo reduces back pressure in the exhaust which in turns alows for the turbo to work more efficiently at higher boost/RPMs that a non-clipped wheel. And a less back pressure = more power . But as a side effect you may see higher boost levels than if not clipped.
NWWagon is offline   Reply With Quote
How much boost can stock turbo handle? Wikid_Kid Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 08-09-2009 03:38 PM
EJ20 Built with stock turbo,how much boost can stock turbo hold? dblrsf1nest Built Motor Discussion 5 10-29-2007 06:34 PM
How much boost with stock turbo? bluestonepath Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 11-06-2006 07:06 AM
how much boost with stock WRX josh...just josh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 05-21-2005 06:04 AM
How much boost does the STI run in stock trim? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-21-2003 02:20 PM
