Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Old 01-21-2005, 12:22 AM   #1
scooby24
Member#: 56414
2004 Forester XT 5MT
Default I know i'm going to get flamed but Intake question
Kay I've got a GPmoto short ram on my STi with Utec stage 2. Well I've noticed that even with maps made for my octane I can't run them because I get DET.
I'm running around 22.5 degrees towards redline and that seems to be the most I can take it without Knock. I raced another Stage 2 STi with cobb and he pulled on me top end...I'm guess because the lower timing.
I've heard you can lose as much as 10 hp for every degree of timing you drop so I really would love to run as much timing as possible. Does anyone with experience tuning an sti with an intake know if the intake could be causing the inability to run higher timing?
Please no flames. Let's keep this mature. I'm fully aware that people don't like the intakes and I will remove it if I know I'm losing power because of it.
Advice por favor? I can throw out my map if anyone would like to see it.
Thanks in advance
-Greg
Edit: for future reference here are the exact mods
1) Invidia Catless TBE
2) GPMoto short ram
3) Greddy Type-S Recirculating BOV
4) Smoothed wastegate
scooby24 is offline   Reply With Quote
Old 01-21-2005, 12:39 AM   #2
kool168
Member#: 61006
Thanks in advance
-Greg
2) GPMoto short ram
try add more fuel?
kool168 is offline   Reply With Quote
Old 01-21-2005, 12:50 AM   #3
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
It could be that you are det because you are running too lean.
blinguskahn is offline   Reply With Quote
Old 01-21-2005, 08:19 AM   #4
scooby24
Member#: 56414
AFR's are perfect...little rich if anything.
Did a 4th gear pull from 3k and AFR's were below 11:1 the entire way to redline. I think I'm going to put on the stock intake and retune and see if I can't get the timing up a couple degrees safely. The main problem I experienced earlier was shift knock so I had to retard the timing right around 5200 rpms after the shift but I've since taken care of the problem by adding fuel at 0% TPS and 5000 to 7000 RPMS.
Meh....I'll let you guys know what I find out.
Old 01-21-2005, 08:32 AM   #5
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Moving..........when will you guys learn? Tuning is engine management, not 2.5L technical.
Old 01-21-2005, 08:56 AM   #6
scooby24
Member#: 56414
Sorry...thought maybe this was STi specific..?
Old 01-21-2005, 09:12 AM   #7
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Do you have logs? Those are the most useful thing for us to help.
What is a smothered wastegate?
mbiker97 is offline   Reply With Quote
Old 01-21-2005, 09:33 AM   #8
scooby24
Member#: 56414
Smoothed wastegate...I like using that term because ported wastegate goes more along the lines of opening the wastegate opening...
No saved logs yet but I will get some tonight after I play with the timing.
Old 01-21-2005, 04:31 PM   #9
hippy
Member#: 36528
2002 Impreza Wrx
Imo, if your a/f ratios are normal the intake most likely isn't the prob(if there is a prob). Also, ya don't usually have to retard timing in higher load areas to stop shift knock. This means that the shift knock shouldn't have effected how hard your car pulls at boost. How about posting your timing map? I know you listed your exact mods, but I mine as well ask. Do you have non-stock spark plugs? On another note, from what I hear the txs maps(non octane challenged) are made on 94 octane. If ya run 93 octane, it would make sense that your engine might det on a basemap(assuming that you're running a utec).
peace
Old 01-21-2005, 04:37 PM   #10
scooby24
Member#: 56414
Originally Posted by hippy
Imo, if your a/f ratios are normal the intake isn't the prob(if there is a prob). Also, ya don't usually have to retard timing in higher load areas to stop shift knock. This means that the shift knock shouldn't have effected how hard your car pulls at boost. How about posting your timing map? I know you listed your exact mods, but I mine as well ask. Do you have non-stock spark plugs?
peace
Spark plugs are stock although may be slightly fouled due to rich condition that a stock STi creates. I don't know how long it takes to foul em up.
Here is my fuel and timing maps:
Code:
Fuel Map
      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]       [0]      [0]      [0]
      [0]      [3]      [3]    [3.7]      [4]      [3]      [3]      [3]       [3]      [3]      [3]
      [0]    [2.9]    [2.9]    [4.3]    [4.5]      [4]      [4]      [4]       [4]      [4]      [4]
      [0]    [2.7]    [2.7]    [4.1]    [4.5]    [4.9]    [4.3]    [4.3]     [4.3]    [4.3]    [4.3]
      [0]    [3.4]    [3.4]    [4.1]    [4.5]      [5]    [4.3]    [4.6]     [4.6]    [4.6]    [4.6]
      [0]    [1.3]    [1.3]    [2.2]    [2.9]      [3]    [3.3]    [3.8]       [4]    [4.1]    [4.1]
      [0]    [0.8]    [0.8]    [1.7]    [2.4]    [2.5]    [3.8]    [4.3]     [4.5]    [4.6]    [4.6]
      [0]    [0.2]    [0.2]    [1.1]    [1.4]    [2.5]    [3.8]    [4.3]     [4.5]    [4.6]    [4.6]
      [0]    [0.9]    [0.9]    [1.8]    [2.1]    [2.8]    [4.1]      [4]       [4]    [4.1]    [4.1]
      [0]    [0.9]    [0.9]    [1.6]    [1.9]    [2.6]    [3.9]    [3.8]     [3.8]    [3.9]    [3.9]
      [0]    [0.7]    [0.7]    [1.4]    [1.7]    [2.2]    [3.7]    [3.9]     [3.9]      [4]      [4]
      [0]   [-0.1]   [-0.1]    [0.6]    [0.9]      [2]      [3]      [3]       [3]    [3.1]    [3.2]
      [0]   [-0.1]   [-0.1]    [0.6]    [0.9]      [2]      [3]    [3.3]     [3.3]    [3.4]    [3.5]
      [0]   [-0.3]   [-0.3]    [0.4]    [0.7]    [1.8]    [2.4]    [2.7]     [2.3]    [2.4]    [2.5]
      [0]   [-1.2]   [-1.2]    [0.1]    [1.1]    [0.9]    [0.3]    [0.4]     [0.4]    [0.6]    [0.6]
      [0]     [-1]     [-1]    [0.3]    [1.3]    [0.6]    [0.6]    [0.6]     [0.8]    [0.8]    [0.8]
      [0]   [-0.1]   [-0.4]    [0.3]    [1.3]    [1.3]    [1.3]    [1.2]     [1.3]    [0.9]    [1.3]
    [0.3]   [-0.4]   [-0.4]    [0.3]    [1.6]    [1.6]    [1.6]    [1.2]     [1.7]    [1.7]    [1.7]
    [0.5]   [-0.6]   [-0.6]    [0.1]    [1.4]    [1.4]    [1.4]      [1]     [1.5]    [1.5]    [1.5]
    [0.5]   [-0.3]   [-0.3]    [0.4]    [1.7]    [1.7]    [1.5]      [1]     [1.6]    [1.7]    [1.7]
    [0.5]   [-0.3]   [-0.3]    [0.4]    [1.1]    [1.1]    [0.9]    [0.4]       [1]    [1.1]    [1.1]
    [0.6]   [-0.2]   [-0.2]    [0.5]    [1.2]    [1.2]      [1]    [0.5]     [1.1]    [1.2]    [1.2]
    [0.7]   [-0.2]   [-0.2]    [0.5]    [1.2]    [1.2]      [1]    [0.5]     [1.1]    [1.2]    [1.2]
      [0]   [-0.2]   [-0.2]    [0.5]    [1.2]    [1.2]      [1]    [0.5]     [1.1]    [1.2]    [1.2]
      [0]    [0.1]    [0.1]    [0.8]    [1.8]    [1.8]    [1.9]    [1.6]     [2.1]    [2.1]    [2.1]
Timing Map
   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]
   [-100]     [34]     [34]     [34]     [34]     [34]     [34]     [34]     [34]     [34]     [33]
   [-100]     [29]     [29]     [29]     [29]     [29]     [29]     [29]     [29]     [29]     [28]
   [-100]     [26]     [26]     [26]     [26]     [26]     [26]     [26]     [26]     [26]     [25]
   [-100]     [24]     [24]     [24]     [24]     [24]     [24]     [24]     [24]     [24]     [23]
   [-100]     [24]     [19]     [19]     [19]     [19]     [19]     [19]     [19]     [19]     [18]
   [-100]     [22]     [16]     [16]     [16]     [15]     [15]     [14]     [13]   [12.5]   [11.5]
   [-100]     [19]     [15]     [15]     [15]     [14]     [14]     [13]     [12]   [11.5]   [10.5]
   [-100]     [19]     [16]     [16]     [16]     [15]     [15]     [14]     [13]   [12.5]   [11.5]
   [-100]     [19]     [18]     [18]     [18]     [17]     [16]     [16]     [15]   [14.5]   [13.5]
   [-100]     [19]   [18.5]   [18.5]   [18.5]   [17.5]   [16.5]   [15.5]   [15.5]   [15.5]   [14.5]
   [-100]     [19]   [19.5]   [19.5]   [19.5]   [18.5]   [16.5]   [16.5]   [16.5]   [16.5]   [15.5]
   [-100]     [19]   [19.5]   [19.5]   [19.5]   [18.5]   [17.5]   [17.5]   [17.5]   [17.5]   [16.5]
   [-100]     [19]     [20]     [20]     [20]     [19]     [19]     [18]     [18]     [17]   [15.5]
   [-100]     [19]     [20]     [20]     [20]     [19]     [19]     [18]     [18]     [18]   [16.5]
   [-100]     [21]     [21]     [21]     [21]     [20]     [20]     [19]     [19]     [19]   [17.5]
   [-100]     [21]   [21.5]   [21.5]   [21.5]   [20.5]   [20.5]   [19.5]   [19.5]   [19.5]     [18]
   [-100]     [23]     [23]     [22]     [22]     [21]     [21]     [20]     [20]     [20]   [18.5]
   [-100]   [25.5]   [25.5]   [24.5]   [24.5]   [23.5]   [23.5]   [22.5]   [22.5]   [22.5]     [21]
   [-100]   [26.5]   [26.5]   [25.5]   [25.5]   [24.5]   [24.5]   [23.5]   [23.5]   [23.5]     [22]
   [-100]   [26.5]   [26.5]   [25.5]   [25.5]   [24.5]   [24.5]   [24.5]   [24.5]   [23.5]   [22.5]
   [-100]   [26.5]     [27]     [26]     [26]     [25]     [25]     [25]     [25]     [24]     [23]
   [-100]   [25.5]     [26]     [25]     [25]     [24]     [24]     [24]     [24]     [23]     [22]
   [-100]     [29]   [29.5]   [28.5]   [28.5]   [27.5]   [27.5]   [27.5]   [27.5]   [26.5]   [25.5]
I know im going to get flamed for this but... andrewhans Proven Power Bragging 112 01-11-2009 01:44 AM
I'm going to get flamed.... smurfwrx Newbies & FAQs 16 10-18-2007 05:51 PM
I know I'm going to get railed for this... wht052.5 Off-Topic 25 06-11-2005 12:30 AM
So I test drove an 2.5RS yesterday, thinking I'm going to get it, but... 3DF General Community 92 02-11-2005 02:00 AM
I know i'm going to regret this but I have too... I am b Off-Topic 32 05-18-2004 07:28 PM
