Old 01-21-2005, 12:26 AM   #1
RogersWRX
Member#: 31617
2002 WRX Wagon
Default Cabin Air Filter replacement
I know a lot of people have cut or made filters to replace the $37 to $50 (yikes!) factory cabin air filter... but I've found a couple of standard air filters that fit and work great!
Purolator - Part # 33590 - $5.99 from Pep Boys
Fram - Part # 3916 - $6.99 from Pep Boys.
Both fit with no modification - just remember, rubber side down, as the air flows from top to bottom!!
Replacement should be about every 10-15,000 miles.
You have to take out all the screws around the inside of the glove box, two on the bottom and one on the right side of the dash.
RogersWRX is offline   Reply With Quote
Old 01-21-2005, 07:31 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
how well does it fill the slot - that filter looks to be 7.6" x 6" which is a bit smaller than the OEM filter which is closer to 7.25 x 8.25 (it's a little over 7 by a little over 8 - I forget the exact dimensions)
I have been tempted to look through the filters at pep-boys for one which would work, but always forget when I am there... I had planned to just cut up a furnace filter (bought the fancy 3M Ultra 1250 - $15 for the 25" x 25" one, and it will make 9 filters)
I don't know why the filter manufacturers don't make a replacement filter for it - they do for other cars cabin air filters...
Old 01-21-2005, 08:02 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...they do.....you just have to order them
Old 01-21-2005, 08:12 AM   #4
Jejunum
Member#: 15773
2011 Impreza WRX
wow awsome! i didnt even know pepboys/fram/purolator sold cabin air filters (as i assume these are).
do pretty much all pepboys carry them?
Thanks!
Jejunum is offline   Reply With Quote
Old 01-21-2005, 01:29 PM   #5
DreddRS25
Member#: 51642
2008 WRX
Does anyone know how different the MY01 RS filters are compared to the WRXs?
DreddRS25 is offline   Reply With Quote
Old 01-21-2005, 05:57 PM   #6
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
from which manufacturer? Fram, Purolator, NAPA, etc. don't list one on their respective sites or in the application guides in places like Pep boys - do you have a part no.?
Old 01-22-2005, 01:50 PM   #7
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
hmmm ... are those engine air filters? I'd be a little convcerned that they would filter TOO well and block the airflow.
Mike Wevrick is offline   Reply With Quote
Old 01-25-2005, 12:55 AM   #8
AjIsDope
Member#: 32660
Or not be a Hepa filter..
AjIsDope is offline   Reply With Quote
Old 01-25-2005, 11:24 AM   #9
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
I cut my own from a home furnace Hepa filter before. This may be a great alternative though.
mbiker97 is offline   Reply With Quote
Old 01-25-2005, 12:39 PM   #10
AjIsDope
Member#: 32660
Ditto. I don't think it works too well though. :-/
Old 01-25-2005, 01:05 PM   #11
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
I'd guess that a intake engine air filter would be at least HEPA quality. (99.97% of all particles >.3um (first pass efficiency)) The problem is that if the Max CFM at the pressure that the blower motor produces (prob not > 12"H2O) is too low there is a chance of not cooling the blower motor properly.
LyveWRX is offline   Reply With Quote
Old 01-26-2005, 01:35 PM   #12
pezman04wrx
Member#: 66558
Wow, new news to me ... I know it's an absolute newbie question, but do 04' WRX's have cabin filters?
pezman04wrx is offline   Reply With Quote
Old 01-26-2005, 03:51 PM   #13
Jejunum
Member#: 15773
2011 Impreza WRX
no way imho! have you looked at engine filters? they are nothing like HEPA filters, atleast in order of filtration. you can see through them ! (not really, but you get the idea).
Old 01-26-2005, 04:51 PM   #14
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Yes - they should. Check behind your glovebox
Hank3 is offline   Reply With Quote
Old 01-26-2005, 04:54 PM   #15
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
I'm thinking more along the lines of cleaning/reuseing the filter. Would it damage the filter to dip it in sope water and hang dry?
Undepelo is offline   Reply With Quote
Old 01-26-2005, 05:27 PM   #16
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Since, according to Subaru, it's got some kind of gel impregnated in the filter material to help catch particles, that might not work so well.
Old 02-04-2005, 11:37 PM   #17
AjIsDope
Member#: 32660
Bump for a part # Scotty.
Old 02-05-2005, 04:14 PM   #18
Jejunum
Member#: 15773
2011 Impreza WRX
bought and installed the purolator filter listed above. it is quite a bit smaller than the box and that concerns me (it can move around). i dunno if it will filter at all because there are other lower resistance pathways (around the filter). thoughts?
Old 02-05-2005, 05:16 PM   #19
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
if the air can go around the filter easily, then the filter can't do it's job very well...
Old 02-05-2005, 05:18 PM   #20
Jejunum
Member#: 15773
2011 Impreza WRX
exactly. so uhh this filter is not so good the only way it might be ok is that it covers the entirety of the blower even when shifted to different extremes.
Old 02-05-2005, 05:33 PM   #21
Uncle Scotty
Member#: 16200
OK buy Nates beans
....damn it ....can't find the damn number....
Old 02-05-2005, 05:38 PM   #22
Jejunum
Member#: 15773
2011 Impreza WRX
what # scotty?
Old 02-05-2005, 06:07 PM   #23
Uncle Scotty
Member#: 16200
OK buy Nates beans
what # scotty?
...no....and that fram filter is too tall to fit in the slot properly.....dunno about the purolator one....
Somebody posted a specific 'cabin' filter P/N that was for another car, that fits the 02+ Impreza like a glove.....and I can't find it....
Old 02-05-2005, 06:51 PM   #24
Jejunum
Member#: 15773
2011 Impreza WRX
damn! the purolator fits in snugly (in terms of height), but is an inadequte size to fill the entire slot. like i said though - covers the entirety of the blower.
Old 02-05-2005, 07:28 PM   #25
RogersWRX
Member#: 31617
2002 WRX Wagon
I found another part # that was closer to the factory 7 x 8" size, but it woldn't fit in properly, because of the vertical tabs inside the housing prevented it from going all the way in... plus it was a real pain to try and squeeze in around the blower moter.
The smaller one seem to fit fine, doesn't seem to be moving around and completely covers the blower opening and filters all the inbound air.
While Fram and Purolater do make "Cabin" air filters, they do not list one for the Impreza application... don't know why!!?? - so this is an "Engine" air filter...
I think cutting one of those "cut to fit" indoor air filters to size, is also a great idea. They offer better flow, but not as good filtering to keep all those dusty dirt roads out of your air vent... Anything's better than paying retail at the $tealer!
Just replaced cabin air filter!! Pics! mostasz Car Care & Detailing 865 07-01-2016 09:29 AM
replacing cabin air filter for a 2004 OBS flyingmachine Interior & Exterior Modification 0 10-26-2009 02:46 PM
Cabin air filter replacement wizzle-stick Tribeca Forum 7 12-22-2008 10:14 AM
Replacing in cabin air filter on my XT SirWilliam Forester Forum 2 01-08-2006 07:49 PM
1 Furnace Filter = 8 Cabin Air Filters Necromancer Vancouver Impreza Club Forum -- VIC 7 12-14-2005 12:19 AM
