Old 01-21-2005, 12:50 AM   #1
blackie
Member#: 42979
03 wrx
blizzzack stage IV
Default will this cure PTFB problems with MBC's??
OK, you get a dual stage mbc and set the lower setting to 10 psi and and the higher setting to 17 psi, then you have a switch that that only lets the 17psi setting come on at lets say 90% throttle and any thing under that will stay at the 10 psi setting. wont this in theory eliminate any PTFB problem??
blackie is offline   Reply With Quote
Old 01-21-2005, 11:47 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
first 17 is tooo much (kaboom)
second unless you flip the switch evey time you enter part throttle nope and you would want a 8 psi setting (wastegate)
basicly no
get a relfash
Old 01-21-2005, 11:55 AM   #3
blackie
Member#: 42979
03 wrx
blizzzack stage IV
im curently stage 4 but using cobbs vf34 map. i rarely hit target boost anymoore so i was going to add a mbc to level the boost back up to 17psi.
Old 01-21-2005, 12:14 PM   #4
CBRDSpeedfactory
Member#: 68255
ALL lots of fast 1s
mostly silver!
Default well..
right now, we are using a utec...but with an mbc, two actually...
im using a DNA mbc and also the ABC from the utec.... i have gotten it to where i can control the overall boost with the DNA, but the ABC allows me to control spiking issues at boost onset....
it has been working pretty well so far...boost response is definetly better than the oem ebc....
avcr would be nice!
boost control in gears and what not....
chad b
CBRDSpeedfactory is offline   Reply With Quote
Old 01-21-2005, 04:40 PM   #5
hippy
Member#: 36528
2002 Impreza Wrx
I know this seems pretty obvious and ya might not wanna do it, but why not just push the throttle past 60%tps or back off the throttle so the boost goes down if you're at/above 7psi?
peace
Old 02-22-2005, 12:51 PM   #6
EdsWRX
Member#: 13881
08 spec b
07 335xi
avcr would be nice!
chad b
I'm curious about how this is set up... care to elaborate? Thanks
EdsWRX is offline   Reply With Quote
Will this cause emissions problems? AM5562 Newbies & FAQs 4 03-25-2008 05:31 PM
will i have any problems with these rims? Sedatives17 Newbies & FAQs 11 10-24-2006 08:18 PM
Will this fix my problem? LuvMyAWD Transmission (AT/MT) & Driveline 0 03-09-2004 09:57 PM
AVC-r EBC, will this get PTFB? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-26-2003 10:46 PM
will this NOS kit work with the wrx smskier Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-16-2002 01:58 AM
