Old 01-21-2005, 03:10 AM   #1
erice1984
Member#: 11778
1980 VWRabbit Diesel
w/AAZ Swap
Default would it be possible to pass emissions if...
Yes, as the topic reads Would it be possible to pass emissions if you had standalone. Not possible. But what if you were to hook up the sensors to the obd-2 ecu for when they plug it into the port and basically have the ecu read everything that is going on but not have any input into the control of the engine.
basically reading, both o2 sensors, tps, air flow, all those other little sensors. Just so the little guy at the emissions place can be happy and plug into the obd-2 port and tell you... your car is fine.
all this given that is the only condition that you fail emissions, not having the obd-2 port hooked-up for the scanner thingy.
-Eric
erice1984 is offline   Reply With Quote
Old 01-21-2005, 12:33 PM   #2
subaru mike
Member#: 30749
2002 wrx
I wanted to ask the same question.
subaru mike is offline   Reply With Quote
Old 01-21-2005, 01:11 PM   #3
CBRDSpeedfactory
Member#: 68255
ALL lots of fast 1s
mostly silver!
Default well.
every car has to go through a driven drive cycle before the sensors are "ready" to be read for an obd port emissions test...
if u had the ecu reading everything while u went through the drive cycle, then maybe, but im not sure...
i wouldnt think it would work...
who knows
chad b
CBRDSpeedfactory is offline   Reply With Quote
Old 01-21-2005, 01:14 PM   #4
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
The UTEC is basically a standalone in this respect. Other than below 25% throttle, the stock ECU is just along for the ride. UTEC'd cars can pass emissions with no problem - the ECU doesn't really know that it's being ignored.
As long as your stock ECU is still hooked up and getting all the signals it needs, (and assuming the car is tuned well enough so the ECU doesn't see any problems), you should be fine.
serendipity is offline   Reply With Quote
Old 01-21-2005, 01:40 PM   #5
subaru mike
Member#: 30749
2002 wrx
So since I have a Link i guess im out of luck
Old 01-29-2005, 01:55 AM   #6
erice1984
Member#: 11778
w/AAZ Swap
subaru mike, thats what i was thinking of, since i have the link as well, i figured if you hooked all the sensors up to the stock ecu and the guys check the obd2 port which is connected to the stock ecu everything might be ok. as long as the tune is good.
Old 01-29-2005, 06:42 PM   #7
SKANk9915
Member#: 80555
04 Spoiler-freeWRX
Platinum
ok, this is my first post as an ultranoob. my 04 wrx is stock stock stock. i was wondering if putting in a turboXS utec would make it fail emmissions. since i dont really know how it works.
SKANk9915 is offline   Reply With Quote
Old 01-29-2005, 10:43 PM   #8
erice1984
Member#: 11778
w/AAZ Swap
someone posted about how the utec only works if throttle position is above 25%
otherwise its the stock ecu doing the stupid work at idle.
Old 01-29-2005, 10:50 PM   #9
Jon [in CT]
Member#: 2992
02 WRX Sedan
There is no way you'll pass I/M 250 testing with a standalone ECU. Your choice, then, is between a piggyback (UTEC) or a reflash of the stock ECU.
Jon [in CT] is offline   Reply With Quote
Old 01-30-2005, 01:41 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
no...
....and it seems that some of you guys are figuring out just exactly why modding a car with certain parts, while living in cretain places should be considered LONG before the $$$ has been spent and that there are some SERIOUS(too often overlooked) advantages to certain combinations of parts over others that have little or nothing to do with performance.
Old 01-30-2005, 11:52 AM   #11
subaru mike
Member#: 30749
2002 wrx
My setup came as a custom package deal, I got 3 years out of it, so Iím happy
Old 01-30-2005, 01:40 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
You MAY be able to get a custom reflash done on a stock ECU so that it will run, and if you have all the necessary hardware still there/available to pass the OBDII stuff and an exhaust with cat(s)....you COULD make it work.....
Old 01-30-2005, 04:33 PM   #13
erice1984
Member#: 11778
w/AAZ Swap
i think we are talking two different things here, there is making the car pass by simply fronting the emissions computers with information (what i am talking about) and the other way is making it pass in an honest way.
Old 01-30-2005, 10:55 PM   #14
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
suposdly there are obd-2 simulators that woudl do the trick i have never seen one but as it is an open protocol they shouldn't eb that hard to make
Old 01-31-2005, 12:29 AM   #15
erice1984
Member#: 11778
w/AAZ Swap
my point exactly, find someone that knows how to program that stuff and they would make money in the aftermarket world, just as long as the dept of trans doesnt find out...
Would it be possible to find brand new a 2006 STi @ a dealer?? BBBsti LTD General Community 3 09-11-2007 09:23 PM
Would it be possible to drop a small-block 350 V8 into a WRX? Asinine Off-Topic 29 09-21-2004 05:47 AM
Would it be possible to make your own FP18g? imprezive one Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-28-2003 02:01 PM
would it be possible to run cobb stage 2, 91 oct ecu with stock downpipe. wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-15-2003 08:50 PM
would it be possible to swap the roof on a 2000 GC8? Chris Lawson General Community 12 01-29-2003 11:11 AM
