Old 01-21-2005, 02:22 AM   #1
erice1984
Member#: 11778
1980 VWRabbit Diesel
w/AAZ Swap
Default wide band o2 sensor, is this one cheap...
I found an O2 sensor,
Oxygen Sensor, Bosch LSU 4.2, UEGO, 0.0 to 5.0 Volts, Wide Band
for pretty cheap, vendor name is innovate technology inc.
I was wondering how it would be determined if this sensor was quality or not.
Thanks
-Eric
erice1984 is offline   Reply With Quote
Old 01-21-2005, 07:45 AM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
Innovate makes an excellent wide band meter. The sensor for it, the Bosch LSU 4.2, is also high quality - it's used in some production VWs and Porsches, for example. The sensor itself can be purchased for $38.29 +shipping from 1stVWparts.com.
BTW, you can't just hook that sensor up to your Autometer A/F gauge.
Jon [in CT] is offline   Reply With Quote
Old 01-21-2005, 07:49 AM   #3
erice1984
Member#: 11778
w/AAZ Swap
lol, yea i knew that. I have this apexi turbo timer it also displays o2 sensor volts. I figure the only difference was the range of voltage and thought the thing might be able to read it... but i am guessing it wouldnt either. What about using a multimeter ?
seriously though, multimeter?
-Eric
Old 01-21-2005, 08:00 AM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
-Eric
You can't measure that sensor's signal directly with a multimeter or your turbo timer. That sensor needs to be driven by a special controller/meter. Such controllers can usually be programmed to generate a voltage output that is proportional to the A/F mixture.
Bottom line: You need to buy a wideband meter to use a wideband sensor.
Old 01-21-2005, 08:06 AM   #5
erice1984
Member#: 11778
w/AAZ Swap
damnit!, I wonder if the link plus is capable of reading wideband...
Old 01-21-2005, 10:56 AM   #6
rewt
Member#: 60794
2007 Solstice GXP
you are still going to need a wideband meter/controller. typically, you run the sensor to the meter/controller unit which correctly operates the sensor. then, you can feed your ECU, gauges, etc., with the appropriate output feed from the meter/controller unit.
so it goes:
sensor -> controller -> ECU/gauges/whatever
rewt is offline   Reply With Quote
Old 01-21-2005, 05:29 PM   #7
lowblow
Member#: 56902
2009 VW Jetta SE
Get the Zeitronix unit...it is awesome.
www.zeitronix.com
lowblow is offline   Reply With Quote
Old 01-21-2005, 05:30 PM   #8
gswrx
Member#: 44701
I hear gpmoto has some also.
G
gswrx is offline   Reply With Quote
Old 01-21-2005, 05:57 PM   #9
quazimoto
Member#: 70395
PLX 300m or 500m are nice.They have a convertor so you can turn the Autometer narrow band meter into a wideband one as well
quazimoto is offline   Reply With Quote
Old 01-21-2005, 07:25 PM   #10
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
If you were on Innovates web site, you probably saw it. The LM-1 package, comes with everything you need (sensor, controller, cables, software, etc). I picked one up for $320 a while back. Good unit and VERY popular in the tuning world.
-jason
jmussetter is offline   Reply With Quote
Old 01-21-2005, 07:48 PM   #11
lowblow
Member#: 56902
2009 VW Jetta SE
I personally use the Twin Tec WEGO with digital display...
http://www.wrxfanatics.com/index.php...ject+gauge+pod
Old 01-23-2005, 03:05 AM   #12
erice1984
Member#: 11778
w/AAZ Swap
the link is busted, may require userid/password to get in it.
Old 01-23-2005, 12:33 PM   #13
lowblow
Member#: 56902
2009 VW Jetta SE
No, they are doing maintenance to the site, so it is down this weekend...try again on monday
Old 01-23-2005, 01:33 PM   #14
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I've got an Innovate kit, Eric. Works pretty good, but the controller box is pretty large. My only beef is the calibration of the output wires sucks if you're not using the same ground to run the unit as you are to run whatever you're outputting to. Mine was off like 0.1v, and they told me that was normal when using seperate ground locations.
Old 01-24-2005, 11:02 AM   #15
Bayley
Member#: 49763
2004 WRX
Jetzt mit 25% mehr Motor!
Remember, the Bosch 4.2 wide band O^2 sensor uses a “heat pump” to control the sensor. Basically, a microprocessor sends a PWM (pulse width modulated) signal to the heater element in the sensor attempting to maintain a constant temperature across the sensor element. Also, the sensor output signal is significantly less than your standard O^2 voltages (0.00V to 1.00V I believe).
There is a reason that wide band O^2 controllers cost a bit of money… they are more complex than most people believe. On a personal note, I run the Innovative LM-1 with their data logging setup and haven’t had any complaints.
Bayley is offline   Reply With Quote
HELP!! Autometer A/F guage not compatible with 2002 WRX wide band O2 sensor?? aznfoos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-09-2004 09:28 PM
DIY Wide Band O2 Sensor Bob O Mid Atlantic Impreza Club -- MAIC 0 12-14-2002 05:43 PM
Solutions to Wide Band o2 Sensor Problem... Needed jfalcon001 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-29-2002 05:01 PM
('93-'01) Wide band O2 sensor voltage range jeffg Impreza Forum 5 06-05-2001 02:26 PM
New Info about my00 wide band o2 sensor??? skidplatez Normally Aspirated Powertrain 3 11-03-2000 11:08 PM
