Old 01-21-2005, 11:19 AM   #1
wonny
Member#: 50241
2004 WRX
Java Black Pearl
Default Cobb Stage II at 10 lbs boost...
I was at 12lbs last week and this morning, I could only get up to 10lbs in third and fourth gear.
I'm going to try resetting the ECU/reflashing the stage two realtime map this weekend, but wanted to see if anyone else had any thoughts.
Would an uppipe or downpipe leak cause this issue?
SPANKS.
wonny is offline   Reply With Quote
Old 01-21-2005, 11:48 AM   #2
Sperm
Member#: 25038
2002 PSM WRX sedan
An uppipe leak certainly would cause a loss of boost. Anyway, 12psi is low as hell for the AP STG2.
More info as to your mods, what octane map, etc. would be helpful.
Sperm is offline   Reply With Quote
Old 01-21-2005, 11:53 AM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I smell leak in your uppipe. 12 is way too low even for people that are too low. Too low folks are at least seeing 14.
Old 01-21-2005, 12:20 PM   #4
wonny
Member#: 50241
2004 WRX
Java Black Pearl
93 Oct gas and map; samco y hose, K&N panel filter...
I don't hear any additional noise when pounding it either.
Thanks for chiming in. I want to get all the possibilities down before I go under the hood Saturday.
Old 01-21-2005, 03:25 PM   #5
Sperm
Member#: 25038
2002 PSM WRX sedan
Check the Samco hose too.
Old 01-22-2005, 04:35 AM   #6
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
What base map you runnin?
darksands is offline   Reply With Quote
Old 01-24-2005, 11:49 AM   #7
wonny
Member#: 50241
2004 WRX
Java Black Pearl
Running the stage two basemap (latest version).
I have noticed that my gas mileage SUCKS. I thought it would be the other way, since I'm not making a lot of boost?
Is there anything terrible about an uppipe leak other than the loss of boost/power? The garage is snowed in and I probably won't get to fix this until next weekend (hopefully).
Old 01-24-2005, 03:06 PM   #8
1DOWNCLOWN
Member#: 50287
02 WRX
i run stage two and run around 16.5-17 at max boost
1DOWNCLOWN is offline   Reply With Quote
Old 01-24-2005, 03:10 PM   #9
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
If you're getting crappy gas mileage, check your vacuum hoses. I found my IC hose going to the throttle body leaking. The clamp there shifted a bit and it leaked. Best I could get is 10 lbs of boost. Sucked. Now after tightening that bad oscar I got about 17.5 lbs(STi). Life is good. So, check your vacuum hoses...
Mika
finnRex is offline   Reply With Quote
Old 01-24-2005, 03:25 PM   #10
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
Im getting 14psi at WOT. I have stage 2 BUT I also have a Helix catted DP as well as a stock catback so I think this is normal. If its not, please tell me otherwise.
Old 01-31-2005, 04:02 PM   #11
wonny
Member#: 50241
2004 WRX
Java Black Pearl
Just to update. I had a uppipe leak which is why I wasn't hitting target boost. I'll probably get to it this weekend. The nut was so loose that I was able to twist it around the bolt with my fingers.
GREAT.
sputtering at 10 lbs boost wrx02racer Built Motor Discussion 16 08-11-2009 03:32 PM
Cobb Stage II+ not hitting full boost raamaudio Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 11-11-2006 10:20 PM
Cobb stage II owners, what boost are you hitting at what RPM? Ohannon7 Engine Management & Tuning 20 09-07-2005 04:55 PM
Cobb Stage II - Boost or EGT Gauge? seasons Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 03-02-2005 03:45 PM
Cobb Stage II - bleeding boost in 3rd Cronos Engine Management & Tuning 5 04-14-2004 04:47 PM
