#1 |
Member#: 24621
Vehicle:2006 Legacy GT 2011 Forester XT |
I'm trying to install my 02 jdm sti headlights, but the passenger side headlight won't go in because there are things blocking it. Did anybody else have this problem? If so what did you do. Thanks
#2 |
Member#: 27679
Vehicle:2002 Impreza WRX Aspen White |
Its pretty straight forward, it took me all of 15 minutes to do both the lights. You sure there isn't a cable blocking on of the clips?
#3 |
Member#: 8403
you can't just put it straight in like the driver's side. you need to put the bottom in at an angle then tilt the top in. after it clears the frame, then you line up the rubber plug on the outside. hope that helps.
#4 |
Member#: 24621
The turn signal/parking light plug was hitting the thick wrapped wires, it's just too thick to bend out of the way. I was able to install it the headlight but I had to remove the plug from the plastic bracket to allow room for the cables. Thanks guys
| Thread Tools | |
| Display Modes | |
| JDM hid blk chrome headlights install problem. | saulgoodyo | Electrical & Lighting | 12 | 02-07-2011 05:37 PM |
| JDM headlight wiring problem | Uncle Ben | Electrical & Lighting | 4 | 05-05-2005 11:48 AM |
| JDM Headlight Installation? | revhard_wrx | Interior & Exterior Modification | 8 | 11-15-2002 12:40 AM |
| JDM headlight install......any problems? | Alexn | Legacy Forum | 8 | 08-12-2002 01:45 AM |
| JDM Headlight installation problem | Conrad Lai | Interior & Exterior Modification | 1 | 04-25-2002 12:50 PM |
