Old 01-21-2005, 03:16 PM   #1
mafiamotorsports
Member#: 67180
1996 OBS(GFC)
94 Mitsu Diamante LS
Outback Sport suspension swap
I tried posting this in the suspension forum But got no answers.Can I swap the legacy outbacks' springs and struts into my OBS for more lift and how much do you think it will give me?Im looking for some more clearance and a stiffer ride.
mafiamotorsports is offline   Reply With Quote
Old 01-21-2005, 07:18 PM   #2
tbd
Member#: 15322
1995 gf wagon
Blue Green Metallic 340
You should know that the legacy crossmembers & subframes are shimmed to allow for the increased height.
If you want to be the test bed & guinea pig, you might try experimenting w/ GD sedan arms, struts & axles to give more lateral length to the drivetrain for clearance. I'm not sure if the CV joints would like those angles. Or maybe you could add the shims from the legacy outback and retrofit them onto your car?
You can tell us after you've tried it?
tbd is offline   Reply With Quote
Old 01-22-2005, 02:54 AM   #3
mafiamotorsports
Member#: 67180
1996 OBS(GFC)
Outback Sport
lol i dunno if I want to be the first.I use the car as a service vehicle for my business.
Old 01-23-2005, 05:29 AM   #4
tbd
Member#: 15322
1995 gf wagon
Default I put up the diagram
http://community.webshots.com/album/257428085qKvbZS
Note the Outback only adapter in the "rear susp" pic.
On a side note, I'd be curious if anyone knows what part #18, labeled "reinforcement bracket" is and where it goes.
Is it similar to those Do-Luck pieces the fit between the control arms under the rear axles? The diagram does'nt seem to point to that piece's mounting location. (I don't have a sedan)
will STI suspension fit on a Bug Eye WAGON? Entire Suspension Swap meat_WRX Brakes, Steering & Suspension 12 04-26-2008 05:45 PM
Suspension options for '02 WRX suspension-swapped BD mattwalters Brakes, Steering & Suspension 10 12-06-2007 01:32 PM
RS > WRX Suspension swap? DDMan Brakes, Steering & Suspension 7 04-27-2002 02:48 AM
Wagon and coupe suspension swap cardin555 Brakes, Steering & Suspension 2 09-27-2001 09:41 PM
WRX to older RS suspension swap DoorKnob Brakes, Steering & Suspension 0 05-07-2001 08:30 PM
