Old 01-22-2005, 12:20 AM   #1
Y2A
Member#: 54545
2005 Acura RSX-S
Milano Red
Default Perfect Sti engine?
Just wondering, if you were to build a perfect Sti engine using parts from any previous/current Sti motor, which parts would you use? Like a USDM 2.5 block with a V8 head or what? Please enlighten me!
Y2A is offline   Reply With Quote
Old 01-22-2005, 02:32 AM   #2
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
i would get a old version 2 block "fully closed deck" with the version 8 sti RA heads.
you would have to get new pistons and rods but you would be able to boost the hell out of it and rev to 8500. perfect.
Rick
scoobydorift is offline   Reply With Quote
Old 01-22-2005, 04:18 AM   #3
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
V8 spec C heads, crawford EJ22G block (closed deck), valve timing controller (dont know if they have them for subies yet, i know there is some for toyotas), Utec, titanium valves and retainers, V6 RA drivetrain, APS turbo or something in that catagory, ARC top mount, Water injection, and all the other goodies.
or, instead of the ARC, flip the intake maniflod around and go for a psuedo (sp?) WRC setup. intercooler in the upper grill and maybe even V mount like they do in the WRC cars... that would be sweet...
Hurley 2.5 WRS is offline   Reply With Quote
Old 01-22-2005, 01:52 PM   #4
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Hey! Crawford is not STI, so thats cheating. Aswell out of most peoples budget.
My vote is the entire JDM V6 STI-RA drivetrain. Then swap in the EJ257, and a larger turbo.
RS_to_WRX_swap is offline   Reply With Quote
Old 01-22-2005, 05:06 PM   #5
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
ok, id scrounge around for a 22b owner and beg them to buy me a block.
Old 01-22-2005, 06:54 PM   #6
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
That block is out dated, and impossable to find.
Old 01-22-2005, 08:48 PM   #7
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Stock block there are still some debate between EJ22, EJ20G, or EJ257. Heads on the newer version definitely flows better, I'm partial to AVCS but given the wiring restriction might be better to do without it. So V7 heads, whatever block you like between the 3, and maybe pistons to make the compression ratio right (like for the EJ22 and EJ257).
kgb is offline   Reply With Quote
Old 01-22-2005, 08:52 PM   #8
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
your point....
if you want me to change AGAIN...
well go with the EJ207 block bored to 96.9mm to be a 2.2, any way, it would be a 2.2
Old 01-22-2005, 09:29 PM   #9
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
You left out one of the best blocks up for debate; the ej207. And AVCS is not that hard to wire in.
Old 01-22-2005, 11:18 PM   #10
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
EJ20G stroked with Ver 7 ra heads and screw the AVCS if your gonna spend that money you might as well put cams, a turbo and some good engine management in there.
DuoMaxwell is offline   Reply With Quote
Old 01-23-2005, 01:03 PM   #11
02SilverRex
Member#: 43475
2002 RWD WRX
JDM Powered
i dont know if this is good but i am installing ver 7 block and ver 8 heads. no trans yet. need $ but i am going to do a 6 spped swap.
02SilverRex is offline   Reply With Quote
Old 01-24-2005, 06:54 AM   #12
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
The ver 7 block sounds good but what internals. The general concensus is that V8 heads are v7 spec c heads so thats a good thing. Have fun, I know I did now I am going back to my think tank its tax return time and I have to go shopping!!!
Old 01-24-2005, 11:10 AM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
where did this ver 6 stuff come from ??
Old 01-24-2005, 02:23 PM   #14
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
what chu talkin bout' willis?
Old 01-24-2005, 06:25 PM   #15
luvmyrs
Member#: 1048
2000 Nothing, thanks
to POS thieves.
Just get a Ver7/8 drivetrain and swap it in. I have one in a 98RS with a pe1820 and txs tmic and this thing kicks your as! enough for me not to need anything else. My 2cents.
Frank
luvmyrs is offline   Reply With Quote
AC compressor, STI engine harness, side feed fuel rails V8Nate Engine/Power/Exhaust 17 07-10-2010 02:28 PM
04 STI Engine vs 05 STI Engine Heater Guy Proven Power Bragging 11 08-20-2009 06:13 PM
Feeler Tn 06 Sti Engine 12k Perfect 2006whitesti Engine/Power/Exhaust 4 05-11-2008 10:20 AM
how reliable STI built engine vs' stock STI engine BBBsti LTD Built Motor Discussion 2 11-04-2006 10:29 AM
