Old 01-22-2005, 12:26 AM   #1
wrx&998rduck
Member#: 79418
2005 wrx
wrb
Default adding a/f meter and aftermarket 02 sensor
hey guys i want to add a autometer a/f ratio gauge, but our cars are 5 volt not one volt like needed. soooo, what i want to do is add another 02 sensor to the exhaust just after the turbo and weld one in with a bung, but my question is more like which aftermarket 02 sensor should i use?
i am figuring honda/acura cause they put out 1 volt, for the meter to measure, but some are 3 and 4 wire does anybody know of one that will work?
or does anybody know of a gauge that will work with 5 volt read input?
wrx&998rduck is offline   Reply With Quote
Old 01-22-2005, 07:33 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The factory A/F sensor (front 02) isn't a 5V one although it is a wideband type and regardless of what type of gauge you have it is not possible to tap into it. While you can install a separate 1V sensor and use it for your gauge, this is not really worth the effort since the narrowband 1V sensor won't give accurate readings outside of its 14.7/1 operating point (stoichiometric). The only setup that will provide true, useful A/F readings is a wideband sensor with a gauge designed to read it.
WTB: 02 Rear WRX lateral links and OEM 02 Sensor forced4door Private 'Wanted' Classifieds 2 03-23-2009 09:34 PM
Vf39 and OEM 02 sensor wrx_513 Engine/Power/Exhaust 1 03-13-2008 08:14 PM
Has anyone come up with a plug and play 02 sensor fix/eliminator?? Davenow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 05-12-2007 12:26 AM
Rear And Front 02 Sensor jefersun Private 'Wanted' Classifieds 1 07-19-2006 10:26 AM
Need a Rear and Front 02 sensor jefersun Texas Impreza Club Forum -- TXIC 0 07-19-2006 10:16 AM
