Old 01-22-2005, 12:41 AM   #1
mpadovano
Member#: 71477
2005 WRX STI
Default Check engine light on and cruise control light flashing
[b]While driving home the other night i was in 6th gear and hit the gas fairley hard to pass some idiot... The car hesitated a bit and then the Check Engine Light came on and the cruise control light was flashing. I have a TXS turbo back exhaust and with a stage two map in the utec. I restarted the car in the stock map and the Lights are still on. Car doesn't seem to drive any differently now, but i am still a bit worried. any ideas?
mpadovano is offline   Reply With Quote
Old 01-22-2005, 12:48 AM   #2
SupersayianNeo
Member#: 49804
2222 WRXSpecV-Type-R
DICK
SupersayianNeo is offline   Reply With Quote
Old 01-22-2005, 02:17 AM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
or more simply:
-you got boost creep
-you then hit fuel cut
-the cruise control light blinks when the CEL comes on (it's normal)
You need to think about a solution to prevent boost creep.
nhluhr is offline   Reply With Quote
Old 01-22-2005, 11:02 AM   #4
Wes_FSTGDB
Member#: 59400
2013 335XI MSport
2008 BMW 335XI Space Grey
boost creep/ boost cut. It's a hard jolt and it sucks, I hate that feeling.
-Wes
Wes_FSTGDB is offline   Reply With Quote
Old 01-22-2005, 02:37 PM   #5
SGOSWRX
Member#: 10921
04 04 STi
12.8 @ 105 mph
The lights shouldn't still be on. Un hook the battery for a couple minutes. That should clear things up. You can still run your stage 2 map. You just need to be careful running at higher speeds 5th and 6th gear in cold weather until you find a fix.
Your choices are to get your waste gate ported on your turbo
or
Run a more restrictive exhaust system. With more restriction from either the muffler or a cat section, usually reduces or gets rid of boost creep.
You may want to put your stock muffler section back on your STi. If your running the Turboxs system you should be able to do that easily.
Also are your running catless? If you are you should get Turboxs's high flow cat mid pipe. That will also reduce boost creep.
I run PDE's catted downpipe and get no boost creep. I got bad boost creep with Godspeeds catless downpipe. So runnng a cat in the downpipe can make a big difference.
SGOSWRX is offline   Reply With Quote
Old 01-23-2005, 12:00 PM   #6
mpadovano
Member#: 71477
2005 WRX STI
Thanks everyone, The lights are not on anymore...i guess i'll have to figure something out to get rid of boost creep now.
Old 01-23-2005, 02:04 PM   #7
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
give your ECU time to learn the cold weather. This happened to me at wide open throttle on the first very cold day in Canada. After a week of even colder air and WOT I have no nore engine cut off. I have a Full TBE with no engine management or modified turbo wastegate.
essogas is offline   Reply With Quote
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Engine light on and cruise control flashing. 07silver2.5i Texas Impreza Club Forum -- TXIC 14 01-04-2010 10:00 PM
Check engine light on and cruise control blinking 06EzSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 05-13-2008 10:10 PM
CEL came on, and Cruise Control light is flashing 07Wagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 12-31-2007 12:12 PM
HELP! Check Engine light on & Cruise Control Light Blinking STiURBO Southern California Impreza Club Forum -- SCIC 21 03-15-2007 01:54 AM
