Old 01-22-2005, 01:52 PM   #1
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Default Help me with my gauge install, Defi BF in 05 STI
Ok, so I am going to get a set of Defi BF gauges that match the STIs oem cluster. The BFs are in a word "perfect" for this. I think I am going to get the EGT, oil press, and boost combo pack. I also really want to get oil temp. The problem is this 4th gauge. I think I am going to put oil press, oil temp, and EGT in the Defi hood that replaces the clock. I would love to put the boost gauge in a pod mounted on the steering column like the stock boost gauge but I cant seem to find one that will hold a 60MM gauge.
Somebody recommended that I get a stock boost gauge but I dont even consider it an option. I have NO respect for the stock boost gauge, its accuracy, or its looks. I could be convinced to get a different gauge brand for boost and use one of the many available 52mm pods but I really want everything to match. I wish Defi made a 52mm version of the BF boost. If not a 60mm Defi then which boost gauge should I get? It must match the sti cluster and be accurate.
If I were to use a non Defi 52MM gauge I would most likely use a auto-meter Gauge Works gauge bezel (Pictured below) and put a wideband O2 on the other side. I like the looks of the Gauge Works gauge bezel but I am worried about the quality, fit and finish of the product. Does this need painted? How well do they fit? Do they look stock?
I am 100% opened to better ideas.
Does anybody have any ideas?
Gauge Works gauge bezel:
dexterous is offline   Reply With Quote
Old 01-23-2005, 07:42 PM   #2
Shavenyak
Member#: 7156
1999 Jeep Cherokee
Shavenyak is offline   Reply With Quote
Old 01-24-2005, 12:04 AM   #3
dexterous
Member#: 23553
2014 WRX - Daily
Looks interesting but I am not sure that I like it very much. Thanks for the response though.
Old 01-24-2005, 12:51 AM   #4
CreoWRX
Member#: 19024
2016 F80 M3
Alpine White
Tom,
If you don't like the stock column mounted boost gauge, I'm selling the complete column-mounted kit (minus the "T" for the bpv line, but includes the steering column piece) with a 45mm Omori mechanical boost gauge in the stock boost gauge's place. It has the red needle/red backlight. Here are a couple pictures;
-Mike-
CreoWRX is offline   Reply With Quote
Old 01-24-2005, 01:47 AM   #5
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Regarding the 4th gauge, you could possibly place it on the center vent, with the vent panel modified/replaced of course:
http://forums.nasioc.com/forums/showthread.php?t=609935
As for the bezel replacement pod, have you perused through this thread below?
http://forums.nasioc.com/forums/showthread.php?t=667454
It may help answer some of your questions.
satrya is online now   Reply With Quote
Old 01-26-2005, 11:06 PM   #6
dexterous
Member#: 23553
2014 WRX - Daily
What about the red JDM boost gauge? Any experence with this?
06 STi Swap into 05 RS. Help me with my grey areas please. STIKindaGUY Subaru Conversions 21 06-19-2014 09:03 PM
Help me with my Defi gauges. UndertoW101 Interior & Exterior Modification 6 03-10-2006 11:21 PM
help me with my gauges before i brake them... nateconnella North West Impreza Club Forum -- NWIC 2 12-13-2003 04:13 AM
Anyone wanna help me with my spring install? moonpie Mid Atlantic Impreza Club -- MAIC 55 06-28-2002 11:58 PM
Would anyone be willing to help me with my gauge setup..? turbocharged North West Impreza Club Forum -- NWIC 10 02-08-2002 04:01 AM
