Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 01-22-2005, 07:22 PM   #1
veightkiller
Member#: 78967
2011 335i
Default water temp...need help.
do you guys know where can i find the oem sensor for the water temp..a picture will help thank's
veightkiller is offline   Reply With Quote
Old 01-22-2005, 07:36 PM   #2
Aspen_2.5RS
Member#: 3310
It's a three wire sensor behind the alternator with a grey plug. You can see it without taking the alternator off, but you have to remove the alt. if you want to replace it.
Cam
Aspen_2.5RS is offline   Reply With Quote
Old 01-22-2005, 07:40 PM   #3
veightkiller
Member#: 78967
2011 335i
no im not going to replace it..i just dnt know wer to put my water temp sensor for my gauge??? any idea????
Old 01-22-2005, 08:39 PM   #4
Aspen_2.5RS
Member#: 3310
I can tell you where I put mine, but I really don't recommend it. I put mine in the heater hose that runs from the firewall to the block on the driver side of the car. This probably isn't the best place for it b/c the coolant isn't as hot there, but it was about the easiest.
Some people stick them in the top radiator hose, but I also heard leaking is more of a factor there. You'd probably have to cut a section of hose out and have some metal pipe to bridge the gap.....and thread the sensor in the pipe.
There may be more options, but that's about all I can think of at the moment.
Cam
Old 01-22-2005, 09:43 PM   #5
veightkiller
Member#: 78967
2011 335i
thank's for the info i guess i have to go to a muffler shop to get the pipe and weld a thread on it ...thank's
Old 01-23-2005, 08:51 PM   #6
BLACK02WAGON
Member#: 32574
2004 STi
WRB 402whp/400wtq
Impreza WRX STi
I replaced my radiator with a speedmonkee all aluminum race unit, perrin hoses, and crucial racing thermostat. When I did this, I purchased a weld in 1/8" NPT bung from Jegs and had it welded in at a local radiator shop. Works perfectly. Make sure that whenever you go to a radiator shop, you have them tig weld anything into a radiator, never let them braze it in....welds are just more reliable.
Good Luck
BLACK02WAGON is offline   Reply With Quote
Omori Water temp gauge help !! Mysta Joe Electrical & Lighting 1 10-13-2008 05:59 PM
water temp sender help subergoo Motorsports 2 04-13-2008 12:26 AM
Water temp gauge help mtnbkrcr Electrical & Lighting 2 03-14-2007 01:47 AM
window water spots. need help nateconnella Interior & Exterior Modification 6 02-25-2003 01:07 PM
wrx water temp gauge help???????? scooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-25-2002 10:22 AM
