Old 01-22-2005, 06:39 PM   #1
DucatiBoy
Member#: 31904
02 WRX Wagon
Default Radiator leak
I noticed my radiator is leaking :-( Seems to be coming out at the top where the aluminum is crimped to the upper plastic. The car is an '02 with 55Kmi. Since it is out of warranty should I get a Subaru OEM replacement or are there better aftermarket brands to consider. One would think that a radiator should last at least 100K in this day and age.
DucatiBoy is offline   Reply With Quote
Old 01-22-2005, 10:51 PM   #2
greenex
Member#: 66625
Blaze Yellow
speed monkee...
greenex is offline   Reply With Quote
Old 01-24-2005, 12:49 AM   #3
20024door
Member#: 80174
I had the same problem with my wrx. It happend at about 12000m. I bought a pwr and I like it alot. Stock rad sucks
20024door is offline   Reply With Quote
Old 01-24-2005, 12:58 AM   #4
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Anything with plastic endtanks will least likely last to 100K
-paK +11
Pakin is offline   Reply With Quote
Old 01-24-2005, 11:05 AM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Hmmmm....I have almost 7 years and 134,000 miles and no radiator leaks.
HG's, yes.
Crank seals?, yes.
Water pump?, yes.
Since I have never replaced it, I don't know of a good replacement.
Old 01-24-2005, 02:30 PM   #6
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Ok, then Charlie has the special radiator. 100K does seem wrong doesn't it?
Simply said, plastic endtanks have to deal with deformation (whenever plastic or elastic) under normal use, they can come apart or no longer hold a good seal. Either that or the plastic endtank (even if they're treated for heat) will over time become brittle or weakened to a point where crimps no long hold the tank to it's sealing surface well.
For a temporary fix, you can try putting some JB weld on it, but don't expect it to last longer than a month or so.
-paK +3
Old 01-24-2005, 08:51 PM   #7
fredj
Member#: 13735
2002 Outback Sport
Sedona Red
If you have not done it already take the car in for the radiator conditioner recall before you spring for a new radiator. It might save you a bunch of bucks.
Fred
fredj is offline   Reply With Quote
Old 01-24-2005, 10:52 PM   #8
Jon [in CT]
Member#: 2992
02 WRX Sedan
Fred
There is no coolant conditioner recall for the WRX and head gasket leaks (which the conditioner is designed to prevent) are rare on the WRX.
What isn't so rare on a 2002 WRX is a radiator leak from a seam at the top. The replacement part for it has been redesigned and has its own filler cap. I've not seen any problems reported with Subaru's redesigned unit.
Jon [in CT] is offline   Reply With Quote
Old 01-27-2005, 09:10 PM   #9
Sonic Yellow 2K3 WRX
Member#: 33236
can you describe what causes the problem and if the car will likely overheat if driven a few hundred miles in that condition?
Sonic Yellow 2K3 WRX is offline   Reply With Quote
possible oil leak and radiator leak MachinesWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-18-2006 07:23 PM
Radiator leak WRXterminate Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-24-2003 12:11 AM
Radiator Leak MissWRX Tri-State Area Forum 5 01-24-2003 06:33 PM
WRX Radiator Leaking WRX4FUN South East Region Forum 25 12-31-2002 04:30 PM
First it's radiator leaking, then clutch master cylinder resorvoir leaking, and then. davidm_sh Warranty Issues & SOA Problems 1 03-24-2002 01:43 AM
