Old 01-22-2005, 07:57 PM   #1
Hola
Member#: 80082
Default Can I put WRX seats in a 1st gen Legacy?
I have a 1993 Legacy sedan and I would like to put WRX seats in it. Does anybody know if they will bolt in or would I have to fabricate something? I've read that they will bolt into 2nd gen Legacys but the seating position will be high. I haven't been able to find anything about the 1st gen Legacys. Do all '02-'05 WRXs (non-STi) have the same seats? Also, is there any way to remove the airbag charge inside of the seat? If I'm thinking right, all WRXs have side airbags in the front seats. Please correct me if i'm wrong. As long as I don't connect power to the seats there shouldn't be any danger with them going off, right? I just want to be extra safe since the airbags wouldn't be doing me any good in the Legacy. I for sure want to swap the front seats but does anybody know if the back seat would work as well? Finally, I've been researching for a while but I can't find a definitive answer to this one: Do the '02+ 2.5RS Imprezas have the same seats as the WRX? I know that the 2.5RS doesn't have side airbags so if the seats were the same otherwise this would be an ideal swap for me. Thank you for any help you folks can give me on this.
Hola is offline   Reply With Quote
Old 01-22-2005, 08:27 PM   #2
snowjob
Member#: 59357
2009 Forester XT
Default seats
First check out www.legacycentral.org It only features 1st gen legacy's, and 2 yes the do fit, but you will be sitting pretty high, I've got 2000 RS seats in my legacy, they bolt up no problems, and are very comfortable. The seating position is less hight.
Hope this helps
Frazer
snowjob is offline   Reply With Quote
Old 01-23-2005, 10:46 AM   #3
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
If you find that they fit, I have a pair of front seats from my 03 wrx sedan that I want to sell. BTW if it helps the 03 seats are height adjustable.
Kent
wrx plus is offline   Reply With Quote
Old 01-23-2005, 12:18 PM   #4
runnyD
Member#: 50786
00 E46 Touring
yes, they bolt right.
I have a set of 03 if you want also..
runnyD is offline   Reply With Quote
Old 01-23-2005, 07:12 PM   #5
jake15
Member#: 36662
1990 legacy dohc 2.2
6speed w/ brembos bishes!
yes they do fit, the front and the rear.
The front seats sit up a bit higher, which is wierd at first, but you get used to it. the only problem with the rear seat is you will have a gap on the side below the edge of the bottom section. it looks like this
the WRX has a little plastic thing to compensate for this.
these seats are in a 1990 legacy
jake15 is offline   Reply With Quote
Old 01-23-2005, 10:48 PM   #6
Hola
Member#: 80082
Hey everybody, thanks a million for the advice. Snowjob, that's a great website. Jake15, those pictures are excellent, thanks. I'm going to try and find a set of seats at one of my local wrecking yards but if I don't find what i'm looking for then I will be looking for some online.
Old 01-23-2005, 11:42 PM   #7
jake15
Member#: 36662
no problem man, just thought i'd throw in another good word for legacycentral. i spend way more time over there than here, as its more geared to my car and everyone over there really knows their stuff.
WTB: 1st gen legacy 4.111 rear diff ASAP in Lehigh Valley kowalski Private 'Wanted' Classifieds 4 12-08-2007 12:49 PM
Anyone put WRX seats in their legacy? BG95 Legacy Forum 11 04-16-2007 08:38 PM
anybody put Recaro seats in their '95-'99 Legacy? Dave G Legacy Forum 32 08-20-2005 05:36 PM
Will a 1st gen Legacy rear sway ('92) fit a 2nd gen Legacy ('99)? whtlegacy Brakes, Steering & Suspension 2 06-24-2004 02:38 PM
HELP! Who's put WRX seats in their Legacy? gtwagon941 Legacy Forum 4 11-08-2003 02:39 AM
