Old 01-22-2005, 07:06 PM   #1
jdchmiel
Member#: 926
Default ignition map for NA ej25
I need to get ahold of a table of load vs rpm of ignition timing preferably from the oem ecu ( I dont think it exists?) but any EMS table wouldd help as well. What I want to do is to compare the load at 2 point for the same RPM, and figure out the difference, so I can usee that difference in the Emanage to retard the timing back to the base value it would be without the air flow signal being tampered with for larger injectors..
jdchmiel is offline   Reply With Quote
Old 01-22-2005, 10:16 PM   #2
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
If you find it, let me know!
Geek Guy is offline   Reply With Quote
Old 01-24-2005, 11:52 AM   #3
jdchmiel
Member#: 926
bump
any ignition table??
'00 and up prefered, will take anything from 2.5 liter motor though
Philosophy in tuning ignition maps for boosted engines 2milehi Engine Management & Tuning 11 04-07-2010 12:59 PM
Ok I need an ignition map for Emanage!!! GregBolby Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-16-2005 10:18 AM
I need an ej25 ignition map, NA preferably jdchmiel Normally Aspirated with bolt-on Forced Induction Powertrain 2 01-21-2005 04:59 PM
Thicker headgasket for NA EJ25 widesuby Normally Aspirated Powertrain 6 08-06-2003 06:19 PM
Link2 map for NA 2.5RS jeffg Engine Management & Tuning 4 03-04-2003 11:05 PM
