Old 01-22-2005, 07:10 PM   #1
mistaboosta
Member#: 68722
Default stall problem after flywheel install
Did anyone experienced such a problem after the lightened flywheel
I've got the Exedy and sometimes the car stalls at idle just all of a sudden.
mistaboosta is offline   Reply With Quote
Old 01-22-2005, 07:18 PM   #2
SaabTuner
Member#: 67608
Next comes the camshaft timing belt ...
Remember that, between combustions (they're not constant), only the inertia of the flywheel, crankshaft, and pully's really keeps the engine rotating. In fact, it's all that powers the car forward when the crankshaft is parrallel with the ground on the boxer 4 cyllinder, because no net rotational-force is acting on it at that time other than "the inertial force".
Sooo ... take away too much weight, sometimes the engine doesn't make it between combustions. All it would take is one or two mis-fires in a row to stal it. Normally that wouldn't even be noticed exept as a bump in the idle.
Adrian~
p.s. One of the advantages to 6, 8 (only with 180 crank), 10, and 12 cyllinder engines is the fact that there is always some amount of "push" from the pistons creating useful torque against the crankshaft. 180 degree cranks in V8's, such as in Ferrari's, and 6 cyllinders are renowned for smoothness; that is part of the reason. They can also have drastically reduced rotating mass for their displacement as a result.
SaabTuner is offline   Reply With Quote
Old 01-23-2005, 09:47 AM   #3
mistaboosta
Member#: 68722
You are right Adrian but as i knew about this already, i didn't go with a lightened pulley or too light flywheel (like ACT or else, The exedy is 14.9 lbs).
btw if there was a misfire, shouldn't i receive some CELs??? I had no CEL yet.
p.s: This happens only when the car is not on a gear. So do you still think that the timing belt would jump some teeths?
Thanks for the nice info
Old 01-23-2005, 11:54 AM   #4
SaabTuner
Member#: 67608
Nah ... just a 15 lb flywheel probably won't make your timing belt jump teeth. Takes a lot of mods to get that far ...
It doesn't have to be a "misfire" ... even a combustion irregularity, such as a late burn, on two cyllinders in a row could cause a car to stall with a much lighter flywheel. Seems to me though, with a 15 lb flywheel you should be ok, or lots of others should be having troubles.
Hmmm ... weird. Not sure how else to explain it unless something got bumped and disconnected in the instal.
Adrian~
Old 01-23-2005, 01:00 PM   #5
mistaboosta
Member#: 68722
maybe the exedy flywheel and rps max clutch don't make well togather??
the car stalls as if it has a serious boost leak somewhere. Once one of my intercooler pipes was loosen and the car was stalling at idle just like this. all of a sudden very smoothly.
thanks again for your help.
Old 01-23-2005, 07:18 PM   #6
SaabTuner
Member#: 67608
Whoa ... is the clutch a lot lighter than the OEM!!???? That would do it!!
Old 01-24-2005, 06:19 PM   #7
mistaboosta
Member#: 68722
well i'm not sure how light or heavy the clutch is
BTW I have the gt-spec headers and the gasket at uppipe-headers connection has a very very serious leak issue. Does that also cause stalling at idle ?
Old 01-24-2005, 07:34 PM   #8
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Leaks don't cause you to stall. Do you have a lightened pulley as well?
Old 01-24-2005, 09:05 PM   #9
quazimoto
Member#: 70395
I'm running the ACt streetlite flywheel(13.9lbs) and a Spec "stage l" clutch kit and cars idles and drives like stock.
quazimoto is offline   Reply With Quote
Old 01-25-2005, 04:49 AM   #10
mistaboosta
Member#: 68722
No my car has only lightened flywheel and in order not to reduce the inertia much I didn't go with another lightened part. Also the flywheel is not so much light as ACT. It's 14.9lbs afterall.
I wonder what causes this stall..
It happens like this:
First the idle becomes rough and rpm changes between 600 - 900 and then the rpms drop and the car stall. Can it be just a rough idle problem ???
I didn't have it until my last garage visit. We installed flywheel, rps max clutch, inlet pipe, smc alky inj.
I guess it is something about the clutch or the flywheel or both.
Old 01-25-2005, 09:29 AM   #11
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Your inlet pipe is probably loose. Check the connections. The Exedy flywheel (or any lightened flywheel) won't cause your car to just stall at a light. It generally throws misfire codes if it is too light. The Exedy isn't too light though.
mbiker97 is offline   Reply With Quote
Old 01-25-2005, 09:30 AM   #12
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
double post.
Old 01-25-2005, 07:45 PM   #13
mistaboosta
Member#: 68722
that might be possible because i realized that I hear the noise of the turbo more than before.
Another thing i found out is that, this happens only after some hard driving.
Old 01-27-2005, 04:57 PM   #14
mistaboosta
Member#: 68722
i've checked the inlet pipe and the smc injection nozzle. No problems there.
It is very weird.
This only happens after I push hard on the car. I stop and take the car out of gear. The idle starts to become funny going up and down pegging between 600 - 1000 and the car stalls.
Old 01-28-2005, 12:06 PM   #15
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
have you cleaned your IAC recently? inspected it at least?
Old 01-28-2005, 01:19 PM   #16
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
definitely clean the IAC it helped my stalling some. I have GFB pully and JUN 14lb flywheel and I can stall the car pretty easily if I am not careful. I am going to put the stock pully back on definitley to help.
Also make sure your grounds are good and you have a quality battery in the car.
but otherwise you are going to have to make sure you help the car find idle. It seems to me that the ECU just catches the transition from decel (decel fuel cut on RS ecus) to idle fueling too late as a result of the revs falling faster with lighter parts.
Hitokiri is offline   Reply With Quote
Old 01-28-2005, 06:24 PM   #17
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Just take a couple minutes and throw the stock flywheel in.
Old 01-28-2005, 07:12 PM   #18
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Vac/intake leak.... and the exhaust leak....
Old 01-28-2005, 07:28 PM   #19
Koua Jones
Member#: 3806
2010 MX-5 Touring
I started getting misfire codes after having my exedy clutch/flywheel installed. My car idles low at ~600 rpm but doesn't stall.
Koua Jones is offline   Reply With Quote
Old 01-28-2005, 09:02 PM   #20
mistaboosta
Member#: 68722
what is IAC??? is it same as maf? if so i've already cleaned it with pressurized air. hope did the right thing.
Old 01-29-2005, 10:36 AM   #21
quazimoto
Member#: 70395
The IAC(Intake Air Control valve) is located on top of the throttlebody.It is used to control the idle air flow.So basicly it is what controls the cars idle.It comes off pretty easy.Just clean it with some carb cleaner and slap it back on.
Old 01-29-2005, 12:13 PM   #22
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you should not clean your MAF sensor with pressurized air. it is a very thin exposed metal wire.
when you remove the IAC, watch the gasket and remove carefully... and DON'T strip the mounting bolts.
Old 01-29-2005, 07:43 PM   #23
mistaboosta
Member#: 68722
thanks for those advices everyone
you're all great
Old 02-07-2005, 02:13 AM   #24
firedog25
Member#: 12570
2002 White WRX
'91 Turbo Miata
I hate to bump old stuff, but I have a Spec Stage 1 and an Exedy flywheel, mine feels nothing like my stocker did. I have to re-learn how to drive it from first gear now.
firedog25 is offline   Reply With Quote
Old 02-08-2005, 04:57 PM   #25
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
If you guys raise the idle 100-150 rpm with deltadash your problems will go away. Actual idle speed is lower with the light flywheel due to the loss of enertia.
Clark
Kingpin is offline   Reply With Quote
Misfire in Cylinder 1 CEL after Flywheel install?? Scoobs2002 Engine Management & Tuning 19 05-13-2008 09:14 AM
Car stalling out after intake install! Saabzilla Normally Aspirated Powertrain 4 02-17-2006 09:24 PM
Problem after stereo install... please help WRXVII Electrical & Lighting 1 11-20-2003 02:33 PM
Help car making noise! Problem after uppipe install jbogli Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-20-2003 10:25 AM
problem after alarm installed Evil Imports Electrical & Lighting 1 04-15-2003 09:56 AM
